Re: Vintage film cameras
Indeed - watching that one.
Looking at sold prices, the Ikonta M is around the £30-40 mark, there are some higher but I don't know why. Hmmm |
Yoko, Hobbycraft sell self adhesive foam that makes good lightseals. Used it in the Trip 35.
Were you already watching it? |
Some kind of self adhesive foam is next on my 'things to buy' list.
I need to learn to look at pictures more carefully too! The Olympus near me on Gumtree, despite having OM2sp documentation, is actually an OM2n. I only noticed that when I'd downloaded the pic and enlarged it. Mave either of you guys got any idea about this vivitar wide angle? Maybe it's intended for close focus work as it focuses down to under 1ft. The distances on the focus ring are correct because I checked on 2 different cameras but then it goes from 7ft directly to infinity and infinity doesn't seem to be in focus. I've not seen that before. |
http://www.hobbycraft.co.uk/black-se...et/571989-1000
Tricky one Yoko, if it just didn't have enough travel it would make sense - are you sure it's indicating infinity on the distance scale? Would be strange for it to focus close and be right but wrong elsewhere. Check the distance at say 1m, measure from the film plane not the mounting flange. Try again at 2m, 3m, see what you get. |
Does that mean that you are going to go for it then Yoko? If making your own seals, I would recommend getting one of these as well http://www.hobbycraft.co.uk/modelcra...mm/614747-1000
Going to a car boot tomorrow, will keep an eye out for another Trip for your friend Yoko. |
Yep, going to go and have a look at the Olympus this evening. I'm not sure what the extra lens is, only that it's a macro wide angle. The seller used it with an extension tube and the ring flash for detailed close ups of dental work.
If you see anything interesting at the boot sale Kenzie, let me know. I ordered some seals from a Japanese seller. I was buying a new skin for a camera so just tagged the seals on. Maybe a little more expensive than Hobbycraft but the string ones are all pre-cut |
Who did you buy from for the skin?need to retrim the fx-d at some point.
Sent from my Xperia T |
This place. Based in Nagoya. They are pre-cut for quite a few models including the FX-D.
http://aki-asahi.com/store/ |
Hmm if the scale doesn't reach the infinity mark - does it manage that with the lens off the camera? If so the the innards may be bottoming in the camera somewhere - for longer distances, the lens needs to come back towards the camera. If it won't reach the infinity mark then could be something inside jamming it. does it have any sort of adaptor ring on it?
