Re: Blipping the throttle.
I've no idea why it works, just that it does. It might be something to do with the gyroscopic effect of the flywheel. |
I will give it a go :cool:
I blip my throttle for the same reasons as the OP on downchanges. You get a much smoother down change and upset the bike much less this way.
WRT blipping the throttle at low speed, this is how I was taught low speed control. This needs to be rapid blipping and I found it did not work to well on the SV so went for the constant throttle / drag rear brake / slip clutch method, which works well for me. |
I do it on all down changes. Not sure it helps a great deal if it helps at all, but sounds good and it makes me feel even better so I do it. I am not sure there is any evidence that it actually works?
I wont go into any massive details explaining it because I cant type correctly at the best of times. |
Also if you're downchanging to use the engine braking, so anything above maybe 3k rpm. Shifting without blipping gives some nasty noises.
I don't like nasty noises. |
I used to do this a lot on my Raleigh Grifter. Made a hell of a difference.
