Re: Tyre bead breakers
Ok, I will just settle for taking the disc off...unless I win that expensive bead breaker in which case I might try using the tyre levers with it on the breaker!:smt077 |
I use a spade
Yeah a spade with a 17st bloke bouncing on it pops the bead quite quickly :smt045 |
I di my 1st tyre with a spade, some hose pipe and a couple of cheap tyre levers just a couple of weeks ago and didn't injure myself at all. I just did it next to a wall for support |
Fair play to you mate, i'll probably get one myself when i've got a bit more room in my garage oh and the brake cleaner/flammable spray works a treat for popping the tyre onto the bead properly |
