-   -   Fitting my BMC filter tonight. (http://forums.sv650.org/showthread.php?t=116997)
Dappa D 04-09-08 09:57 AM
Re: Fitting my BMC filter tonight.....
hi quick update guys...
put it in last night....and as thought at about 5k revs it starts spluttering/kangarooing etc....but i did like the noise so gonna keep it....(plus i plan for this to be my track bike in 2 years if all goes to plan)
i was looking at the haynes last night looking for a guide on how to change jets...got a bit confused as it mentions "main jet" "somethin else jet"...."jet pin"....do u know if there is a guide around anywhere or in the haynes manual?....
im a complete mechanical novice but willing to give it a go....
thanks for the linky gonna order some today
edit...just clicked the link i guess its the main jets i change?
boo86 04-09-08 10:14 AM
Good lad. I would keep it too. Power corrupts !
It's a piece of p**s to swop the jets. It's only the MAIN JETS you need to worry about.
Message me your email and I'll forward you a pdf and some other notes.
Basically standing on the left hand side of the bike (curb side) remove tank, remove air box, loosen inlet manifolds, this should alow the carbs to be twisted up and over to expose the float bowls. There's 3 screws on each. You don't need to worry about any of the pipes or cables on the carbs as you can just ignore these and remove the float bowls. Put any cigarettes out as petrol will come out of the float bowls, but not much. There's 3 screws on each undo these and pop them off. The MAIN JET is the big one smack bang in the middle. The haynes has an exploded diagram. Unscrew it, screw your new bigger jets in, just a flat bladed screwdriver does, best if it's short as space is tight. Clean up the float bowl mating surface and reasemble. Put everything back together and job done. Clean out the float bowl while it's off. There'll probs se some junk in the sediment pot at the bottom.
The spark plugs will tell you if your jetting is close. There's also various tests you can do. You mayhave to go to 160s depending on the exhaust you've got. You may be fine with 152.5s. Only use Mikunis.
Dappa D 04-09-08 10:34 AM
nice one boo86 thanks fot that,
gonna pm email addy now....
I have the ebay shop open on a tab trying to decide which ones to buy....(seriously skint so cant get both today - would mean no fags today lol!!)
might wait till tomorrow (get paid) and then can do it all on same day should first ones not be right....
will it defo be one of the sizes u have mentioned or could it possibly be a different size?...
I have a Viper SS end can...dont know the exact model unfotunately...
drag 04-09-08 01:57 PM
Interesting read so far gents, I've been toyin with the idea of changing my fillet to a BMC one also, and rejetting, the garage always told me not to bother ( I've a KnN foilter and a CCC can on at the moment, baffles are for girls ;) )
Also should fit those tank spacers for a bit more air in the system also.
I assume along with rejetting you shoudl rebalance the carbs after you install Tank spacers ? etc
Dappa D 04-09-08 02:09 PM
drag if you wanna pm me ur addy i could send over what boo86 sent me....some good info
drag 04-09-08 04:03 PM
Shall do
northwind 04-09-08 04:51 PM
They were right, the power gain's pretty small and the hassle is not pretty small. Unless you're properly tuning an SV, the best air filter's the stock one.
Dangerous Dave 04-09-08 05:59 PM
Originally Posted by Dappa D (Post 1613759)
FM205/10RS
That'll be the race version, the 'RS' has a small mesh filter in the base too.
:crutches: :smt013
