Re: More Mods and Money :)
they are £30+postage, no fixings either, so i guess thats the prep work.
kk not that bad |
Rear end looks good. Whats that on the exhaust?
The finish is not the best so will need undercoats and sanding for a good base for paint job, edges needs a bit of care too to give a better fit. In terms of fitting, will need to drill holes for plate, indi wire, plate light and 2x at tail for the cowl underside screws. The rest of the undertry is held in place by the cowl trim. Hth :D
I fabricated a bracket up myself using some steel. This bracket was for the numberplate and indicators.
The prep that needs doing is basically the edges could do with rolling around the edge by the rear light. The gel coating is very thin, single layer im almost certain. I will spray a coating of thinned down spray filler on top and to get it perfectly smooth and flat. once this is done primer and paint can be applied. I wouldnt reccomend this product though to anybody who intends to pay somebody to paint it, this is because it will cost a fair wack to do, i would have to charge around the £100 to make ends meat if somebody was paying me. ooh and whats what on the exhaust? |
yep it is indeed, ive got a hyperpro fully adjustable on the rear. That purple can is the adjuster.
