-   -   handlebar uprise for SV650S? (http://forums.sv650.org/showthread.php?t=130718)
maviczap 30-04-09 04:10 PM
Re: handlebar uprise for SV650S?
Originally Posted by Flagship (Post 1889648)
This sounds interesting and I would like to try on my '99 SVs.
Are there any specific year of FJ1200 to fit mine?
I think they are all the same
xXBADGERXx 30-04-09 11:37 PM
You can get the ABM comfort kit which Org members can get 15% discount for using my code on 998cc.com ..... another one I have heard is using the clip-ons from a Honda NightHawk , these have about an extra inch of rise over the SV ones , best bet is to search eBay on a worldwide search as I think the NightHawk was a US model . There are also Helibars , Gilles adjustable Clip-Ons and LSL also do clip-on kits as well .
Jayneflakes 21-05-09 10:53 AM
I knew if I looked hard enough I could find the info I needed. I am not enjoying the Low bar position on my SV and am thinking of a riser bar so this thread has been wonderfully useful. Now off to scour the net for Helibars because if I am honest, I have no idea what they are!
You lot are tops!
Hugs
:smt003
maviczap 21-05-09 11:17 AM
I still have the set of FJ1200 clip ons in my garage and if I ever get my GSXR front end, I will also have a set of LSL high rise clip ons for SVs, which I won't need.
The FJ clip ons are near identical in height to the LSL's, but a 1/3 of the price. All they need is a hole drilling and tapping in the right hand one to mount the brake master cylinder.
embee 21-05-09 06:06 PM
I have the FJ1200 bars on my curvey.
Be aware that they are not a direct fit, there's not enough clearance to get round the top yoke, but being forged steel risers they can easily be ground to get the clearance and still leave plenty of meat.
I fitted them swapped left to right, the FJ bars are marked L&R, to get a better position. You need to drill the holes for the switchgear, and I welded a small tab on the right hand one and drilled&tapped it for the brake fluid reservoir.
I think the brake line is about 30mm longer than stock IIRC. Other cables etc fit fine. Make sure you get the FJ bar ends with them, they are totally different to SV weights.
The riding position is vastly improved IMO, much easier to use in town.
http://i258.photobucket.com/albums/h...G_2946_25R.jpg
kerby 05-07-09 05:54 AM
I think Honda VF500F clip ons are the same as the nighthawk bars.I have fitted nighthawk bars to my wifes curvey and cosidering doing it to my pointy.
Has anyone fitted them to a pointy or indeed the FJ bars?
Specialone 05-07-09 10:17 PM
Originally Posted by SV650Mert (Post 1885821)
Hi everybody!
I just bought my ride (SV650S) and litlle bit fed-up of the racing-riding position. Do you know is there any kits to uprise my handlebar for more relax longway trips? Or any ideas?
I have ordered the kit below, £308 delivered (still hasnt turned up actually after nearly 2 weeks)
Originally Posted by exgsrider (Post 1887858)
I have fitted an uprise kit to my SV650S K6 - got the kit from website 998cc.org - comes with yoke, risers. Renthalls, extended throttle cables and braided lines. Looks great and riding position brilliant.
Hope i like mine ;)
That information 2 weeks ago would have been beneficial :(
lee67 06-07-09 08:38 AM
did mine the easy cheap way...naked top yoke, renthals bars, new longer braided hoses and re reouted all swithcgear, clutch and throttle cables and has worked a treat..a joy to ride now...this was on a k4 pointy s'....no problems in re-routing throttle cables either'':D
http://img443.imageshack.us/img443/3...teredsv008.jpg
xXBADGERXx 06-07-09 09:48 PM
The search function is your friend on this site or even just asking in SV talk and tuning :smt040 . I am sure it is under the Hardware section as well , well worth a look if you are considering anything hardware related as there is bound to be something related knocking about in there
xXBADGERXx 06-07-09 09:51 PM
Did you not need the bottom yoke from the naked as well ?
