-   Bikes - Talk & Issues (http://forums.sv650.org/forumdisplay.php?f=129)
-   -   speedo not working, any sugestions on the problem? (http://forums.sv650.org/showthread.php?t=141373)
yorkie_chris 23-10-09 05:54 PM
Re: speedo has cr*ped it :/ any sugestions on the problem
Mileometer just counts the same pulses as the speedo.
I think it is rotor, this is much cheaper than sensor.
Neeja 23-10-09 07:01 PM
Originally Posted by barwel1992 (Post 2074404)
they think its the sensor thats gone (£111.00)
No no no no no no no! Don't believe a word they say. It'll be the rotor. It's made of yoghurt-pot strength plastic. If it was the sensor then I doubt you'd have got the funny readings - it probably would have stopped altogether. The low readings you were getting was probably a result of a few of the rotor pegs snapping so it wasn't engaging properly - just enough to turn the sensor drive, but not enough to turn it at the right speed.
The front wheel comes off, little plastic bits come out. Buy new rotor - mine was about £20. Take it back from the dealer and get a 17mm spanner - you'll be able to fit it yourself and avoid an hour's labour (comprised of them making cups of tea and going "Hmm" a lot). Simples!
Edit: YC got here first. Should check the rest of the thread instead of jumping straight from an e-mail ;)
barwel1992 23-10-09 07:22 PM
well they are checking it it tomorow i will see what they say then purchase the tool buy a second hand one from ebay (£30 for the whole lot) with 28 day waranty and then do it my self :)
PS can some one tell me where it plugs in as my wires are taped to geather (to make them look neet) so i carnt folow were it goes
the shop is bikersworld daventry so not a stand alone dealer and the one lad thinks its the bit you lot think it is and sead it cost £17 but then there laybor is steep at £50 a hour.
they are going to be fitting my braided lines for me and im suplying all the stuf :) as im having some lines made up for me because the renthals make the lines to short :)
barwel1992 23-10-09 08:17 PM
lets just hope they dont charge to morrow :)
Neeja 23-10-09 09:32 PM
Go to Halfords. Buy one of these. Your brake lines don't need to be fitted professionally - it'll take all of about 5 minutes to fit them, and maybe another 15-20 minutes to bleed the system (if it's your first time doing it).
The ratchet set linked above will be sufficient for almost every general maintenance task short of chain adjustment. At £14.99, if you do one job that would charge an hour's labour (say, for instance, changing brake lines ;)), you've just saved yourself £35 at their rates.
I started doing all my own maintenance a little earlier this year, after graduating from just doing oil+filter changes, chain adjustment etc. It's really not that hard. Get a haynes manual and it'll walk you through everything, and things like brake lines are common sense - you take the old ones off, and put the new ones on in their place, making sure nothing rubs or pinches and the hoses are routed correctly :)
If in doubt, ask for local .orgers to give you a hand - there'll be someone near you who can show you what to do and help you through it. In no time you'll save yourself a fortune in mechanic fees :thumleft:
madnlooney 23-10-09 10:40 PM
looks like mine is playing up too. it was reading at 0 then i pulled into garage and wiggled the cable and seems to be working ok. Is there a way the wire connecting to the sensor can be done up or is it a complete unit? sensor and wire?
barwel1992 23-10-09 11:22 PM
aparentyl its seperate and just plugs in (google search turned up a parts thing)
madnlooney 24-10-09 02:34 PM
Re: speedo not working, any sugestions on the problem?
spoke to block at dealers and he think my problem could be the rotor as he mentioned they dont sell many sensors infact dont stock them but they do sell the rotor which does go more often. so i think i will pick one of these up and see how i go
yorkie_chris 24-10-09 04:17 PM
Tool for front wheel? It's a 12mm allen socket, don't buy owt special.
barwel1992 24-10-09 09:25 PM
^^^ yup aparently they dont even have a tool(suzuki dealer) and have been told to get a 12mm alen socket :)
and aparently the whole thing is gone (dident even take the wheel off) so i told them im not going to buy it from them lol should have seen the look on his face.... any way they are geting my money when i come to do the brake lines.
going to get the whole thing from ebay then see whats actuly wrong "speed sendor or rotor"
