-   -   Which gaskets must I replace when removing top end? (http://forums.sv650.org/showthread.php?t=160376)
barwel1992 05-12-10 08:36 PM
Re: Which gaskets must I replace when removing top end?
Originally Posted by hongman (Post 2435601)
What kind of bhp increase do you hope to get with busa pistons?
no idea, they are lighter than the stock ones, they are the same size so dont over bore it, in theory engine should rev easier so mainly aiding acceleration
will find out when i get it on a dyno
hongman 05-12-10 08:45 PM
Would be interested to know the results...
barwel1992 05-12-10 09:21 PM
well what im planning to do is get it dyno'd then get it tuned at a later date just to see how much more bhp i get from a tune (even if its 1bhp through the range, it still an improvement not that it runs ruff untuned )
beabert 06-12-10 07:45 AM
Tad lower torque id imagine because they are lighter?
barwel1992 06-12-10 09:03 PM
yup but the lower weight means the engine dosn't have to work as hard to change the direction of the pistons, so in theory the torque would be not be lower but shift it further up the rev range, i think thats what my tutor said
and wont really know what it does becasue im doing some other bits at the same time, cleaning up the ports and 3 angle the valves
hardhat_harry 06-12-10 10:58 PM
You might as well get the full gasket set as 1 x head gasket is about £35 but the full set is £110 (or £70 if you can get them at cost)
barwel1992 06-12-10 11:00 PM
how would i get them at cost ?
and whats included in the gasket set
beabert 07-12-10 03:25 PM
Getting pricey isn't it.
barwel1992 07-12-10 06:19 PM
lol getting the piston rings and gaskets all in inc P&P for £120 so not bad, all coming from zoran in America when i get round to buying it
