Re: SV650 K3 Clutch Drag & Front Brake issues
Hi Longway
Have you managed to sort out your problem with the front brakes?. I have exactly the same problem-very low speed it feels very much like a kind of lots/little/lots/little braking action (interesting when you want to come to a smooth stop!) On a previous bike i had a warped disk this (braking action) felt very similar but with added lever pulsation which is not present on the sv, so i am hoping this time its not warped disks just something cheaper/simpler! I had the calipers stripped and cleaned to help it through the mot (failed for an other reason) this has not helped. If i manage to get them sorted out i will post what done the trick. |
Not specific to SV's but I have experienced low speed "grabbing" on other bikes which was due to only part of the disc being glazed, the other part had slight corrosion marking caused by not using bike after a good wash ! Apparantly rust has a different coefficient of friction compared to a clean disc . The simple remedy was to deglaze entire disc area with some very fine wet and dry. NOTE, the brakes don't work so good for a few miles. I'm not recommending the above, It's just what I've done in the past and it works for me, Fraser
Cheers Fraser. I shall start with trying that. Paul
