-   -   Coolant change question after interesting dealer suggestion? (http://forums.sv650.org/showthread.php?t=174622)
StitchSV 27-01-12 07:30 PM
Re: Coolant change question after interesting dealer suggestion??
Thanks
Will take a look in thr morning to see if I can work out how the pipes fit together.
Originally Posted by maviczap (Post 2655036)
If you take the top hose off and flush through with a hose, gravity will do the rest
maviczap 27-01-12 08:34 PM
1.6 lites capacity, refill with 50:50 mix of antifreeze & water, usually distilled water if I remember correctly
StitchSV 27-01-12 08:39 PM
Thanks. I've got 2L of pre-mixed castro coolant and 5 l of distilled water to flush the system with. Only thing i'm missing is the damn crush washer.
yorkie_chris 27-01-12 08:45 PM
Tap water is fine to flush the old stuff out.
I've never had a problem reusing washer.
StitchSV 27-01-12 08:53 PM
Hope so.
I had to re-use the washer when I changed the oil a few months ago and have had no issues. I've since picked up a handful of oil plug crush washers though just not the plug.
Hopefully can re-use if needed.
Sid Squid 28-01-12 12:53 PM
Unless the washer is obviously damaged whilst removing it, and it almost certainly won't be, you can re-use it. A hose pipe from the garden tap is what you need to flush the system - 5l of any fluid is nowhere near enough to do anything to clean it out.
The coolant plug washer is about 6-7mm ID, the oil drain washer is about twice that.
Be very very careful when refitting the plug - it's a steel bolt fitted into a thin light aluminium casting, don't overtighten it.
StitchSV 28-01-12 02:46 PM
Well It's all done.
Changed the coolant and spark plugs. The coolant plug was fine and I reused the washer without any problems (yet!).
The bike has now doen 6456 miles and the spark plugs were not in a good state. They looked like they needed changing.
Only used about 1.4-1.5 litres of pre-mixed coolant to refill the system and the overflow tank.
Also managed to get a rounded nut off the hugger sorted and I also replaced some of the plastic lugs on the lower fairing and then went for a 60 min to make sure all is well.
I may even have a beer tonight!
Thanks for all the helpful comments.
Red ones 29-01-12 04:26 AM
Sorry? Did you miss a zero off there?
StitchSV 29-01-12 09:28 AM
Lol. Nope.
I was surprised at how bad they looked but then again this is the first set of bike plugs I've seen so nothing to compare it to.
