-   -   Which USD front, which shock, wider back wheel? Again. (http://forums.sv650.org/showthread.php?t=177095)
adam1983 05-04-12 07:50 PM
Re: Which USD front, which shock, wider back wheel? Again.
Originally Posted by Bibio (Post 2691141)
you wont get a USD front end for 2-300.
expect to pay:
forks = 150>
front wheel = 100>
mudguard = 40>
callipers = 50>
yokes = 100> (if you want to keep the naked look with renthals then you will need a custom yoke make)
brake lines = £40
wheel spindle = £30>
nuts bolts etc.etc. £40>
discs = £80>
performance + tart = lodsa cash
so save my monies for a while...got it
so rear shock will be done 1st :D
any other mods i should be looking at?
maviczap 05-04-12 07:53 PM
I'd change the front springs first, as a cheap quick mod, then the rear shock.
If you can't afford USD front end, then emulators are also a good option
andrewsmith 05-04-12 08:00 PM
This!
As bib said your talking over a grand if your sorting both ends properly.
I've looked into doing a SM SV650 and just the front end was £600,
Yokes was North of £300 (Custom fit front end)
Rear wheel rotor £300 (Rim and spoking make this over £500)
Shock to suit £700 (Maxton custom)
adam1983 05-04-12 08:00 PM
never changed springs before how much of a balls ache is it
maviczap 05-04-12 08:22 PM
Undo a nut, take out spacer, take out OEM spring, replace with new spring.
But the full job will mean taking the forks out to change the oil, replace and measure air gap, then install new springs.
If changing the springs sounds like a ball ache, doing the front end swap is a big job!
andrewsmith 05-04-12 08:31 PM
And the rear shock...
http://www.corporateflyfishing.com/i...twin/zx10a.jpg
maviczap 05-04-12 08:34 PM
Andy, you need an ABBA stand :p
andrewsmith 05-04-12 08:41 PM
A Berlin and a workshop is just as effective.
Looking at the options to strip a bike back atm
Bibio 05-04-12 08:42 PM
if your wanting performance (nice suspension) then don't bother with emulators go straight for cartridge drop in. cbr600 f3 or zzr600 1996-2003 (e model) both of these are 41mm. you change the stanchions into the sv tubes, they stick up past the yoke 3cm. the kwak ones can be had for very little money. then spend the cash on a nice rear shock from Nitron. svracer on here will supply you one for £360 built for your weight.
ok so it wont be tarty but it will give you super duper suspension and this is what it's all about. plus no messing with speedo setups or wondering what part fits with and where.
littleoldman2 08-04-12 05:37 PM
Is a GSXR 750 K3 shock any good for a curvy?.
