-   Bikes - Talk & Issues (http://forums.sv650.org/forumdisplay.php?f=129)
-   -   Removing number plate light? (http://forums.sv650.org/showthread.php?t=191790)
Pricey12 19-02-13 06:28 PM
Re: Removing number plate light?
Originally Posted by pookie (Post 2833290)
I dont think you need a number plate light for the MOT although the police might take a closer look
Especially with a 9 x 3 number plate ;)
Pricey12 20-02-13 09:38 AM
Here's some photos of what im seeing. For the life of me I can't see how to access the bolts holding the number plate light in. Also, how do I remove the plastic fairings around the seat. Have undone all ths bolts but they won't shift!
joshwalker094 20-02-13 09:44 AM
No pictures there
joshwalker094 20-02-13 09:57 AM
Nothing like a pointy snow plough. Errr Fack knows, can't see anywhere where you can unbolt it from.
Good luck
Geodude 20-02-13 09:57 AM
Dont see any pics either but heres one that might help you a bit
http://www.sv650.org/gallery/pic7/Old_Rear_Fender.jpg
Geodude 20-02-13 10:08 AM
I see pics now :) it should be attached with a couple of bolts and spacers iirc on the inside (see pic and follow wire) of the undertray. HTH
Geodude 20-02-13 10:26 AM
Yep :) not too hard when you have done it before, get yourself a cheap copy of haynes off evilbay or download a pdf version it will help loads as will getting your hands in there but try not to break to much learning like i did ;)
NTECUK 20-02-13 10:27 AM
if your removing the plough the light will come with it.
Geodude 20-02-13 10:32 AM
The manuals for download are here pricey https://docs.google.com/folder/d/0B6...MVU/edit?pli=1 HTH
NTECUK 20-02-13 10:34 AM
Oh and for all you trouble its gona flike dirt water up the back of the bike when you fit a new tail tidy
