-   -   Throttle cable routing/longer cables? Curvy. (http://forums.sv650.org/showthread.php?t=212910)
Aligowers 02-09-14 10:25 AM
Re: Throttle cable routing/longer cables? Curvy.
The s model yoke is really thin. My mate got billet inserts made up at his work to fit inside the top yoke. I got the CNC kit second hand for £55 so i cant really complain to much my renthals have arrived today just waiting for a few other things. Might make a wee video if anyones interested but its not a difficult thing to do hopefully :)
maviczap 02-09-14 11:22 AM
Originally Posted by llcoolj (Post 2976889)
Hi this sounds interesting, I'm looking switch the clip ons for a handle bar.
Just out of curiosity, could not drill the original top yoke and mount high risers?
Like Ali says, you need to reinforce the top yoke if you're going to do this
llcoolj 02-09-14 01:09 PM
Thanks guys for the advice.
Yes that is cheap, I'm on the look out too :-)
Aligowers 03-09-14 03:59 PM
Just fitted the new CNC yoke. I put renthal low bars on the not the ultras. I had to replace the clutch cable and brake lines. The orginaly throttle cables fitted fine when i routed them behind the forks. Bike feels great a million time better than before.
Trev B 03-09-14 06:08 PM
Welcome to the comfy club mate,the difference is incredible and I think it makes for better vision especially at junctions looking left and right!!!
Aligowers 03-09-14 09:38 PM
Your right there buddy noticed that straight away. I wish i had got this kit when i first got the bike what a difference.
llcoolj 06-09-14 12:12 AM
I be fitting a non S OEm top yoke on my S model. It will come with the std high risers. I be aiming to fit std or low renthal bars.
Does anyone know what length brake cables I should get?
I believe std throttle and clutch cable should be ok?
Thanks
Aligowers any pics? :-)
maviczap 06-09-14 06:53 PM
Thanks
Naked length brake lines should give you plenty of slack to allow for suspension movement.
Otherwise fit the bars and measure out the length with some string, and allow a good extra margin for suspension movement. If they're too short & tight, its an MOT failure & not worth the risk of a line popping out of the banjo fitting on full suspension extension. Sudden brake failure is not good
llcoolj 06-09-14 09:24 PM
Ok, thanks for the advice will get some pics when it's sorted
Aligowers 06-09-14 10:06 PM
I had to replace my clutch cable and choke cable with naked cables. Throttles fine if you reroute behind forks. No idea how to upload a photo lol
