Re: Exhaust pipe cleaning
I used Optiglanz to great success, well until a sudden gust of wind caused me to breath in a lungful! They warn users not to breath it in and they are not wrong. Great cleaner, but it tastes and smells vile... :D
Thanks Jayne, I'll give that a look and I'll
try to limit my substance abuse to less toxic aerosols... EDIT: Yee-ikes that is expensive! |
optiglanz is what is what they use for 'acid tank clean' on automated production lines for stainless steel, you need to buy 100's of ltr of it. you can however get a whole host of 'pickling paste' substances for low run production that is applied by hand, only problem with these is that they give a dull finish.
down at the workshop there is a hand held ultrasonic picking machine that makes very very short work of the job :-) |
http://imgur.com/dwg0eLt
http://imgur.com/Zleclwm When i got my bike, the exhaust was powder coated black, if you look at the picture you can see the colour of the rear pipes i couldn't get to till i took it out today. Harpic Max 10 the same one in the picture is the best cleaner ive used. as soon as you put it on you can see the reaction happening instantly. |
That's good info, thanks.
I want to do it in situ and don't want to spray a powerful acid onto the rest of the bike so Harpic applied with a brush is looking likely at this moment. The fairing lowers are going to be back with me this week so I will be doing the job in the next few days. |
From the Street Triple Forum: Fry Powerflow Flux. £6.19 from Screwfix Method: acquire wife's toothbrush. Run engine until pipes really hot. Apply flux with brush. Wipe mess off with damp cloth. Rejoice at sight of clean pipes - as quick and easy as that! :D ps: don't forget to clean & return toothbrush. |
ROFL! I actually have some flux in my plumbing kit! I'll just pop up to the bathroom.... :smt081
Thanks for that, I'll let you know how it goes (if she notices). |
Many active solder fluxes have hydrochloric acid in them, the same acid that harpic contains.
