-   -   Loose Key - SV650 1999 (http://forums.sv650.org/showthread.php?t=230839)
R1ffR4ff 09-10-18 10:15 AM
Re: Loose Key - SV650 1999
Originally Posted by ophic (Post 3093222)
Anyone tried ACF50 in the lock?
This is supposed to have lubricative properties.
I've been using ACF50 in my Ignition barrels for well over 10 years and never had a problem.Also works it's way down to stop corrosion on the electrical connections I suspect.I treated the Ignition Connector block with Switch cleaner and then ACF50 when I do my block connector servicing.
HTH :)
