-   Bikes - Talk & Issues (http://forums.sv650.org/forumdisplay.php?f=129)
-   -   Bolts (http://forums.sv650.org/showthread.php?t=237875)
DarrenSV650S 15-11-20 04:40 PM
Re: Bolts
No it's aluminium so no chance of drilling it wider
https://i.imgur.com/wV8C6zH.jpg
https://i.imgur.com/p9zTjQ4.jpg
Adam Ef 15-11-20 06:50 PM
Re: Bolts
I had similar on a bicycle stem. Easton stems use m6 bolts that have a head the size that an M5 bolt would have. Had to grind a bit off the head for it to fit in.
Craigg 01-01-21 02:20 PM
Re: Bolts
https://www.stainlessautomotivefaste...2ki9p284nn3c57
I bought from this place for a similar issue with my old SV. they give the head width measurement so you can see if it will work.
I dont think you will get smaller than 14mm for an M10 bolt though!
DarrenSV650S 01-01-21 03:47 PM
Re: Bolts
I used a file on one bolt with the bolt held in a drill. It took a long time and as NedSVS said the file got clogged up pretty quickly. It's an old file so I wasn't too bothered. Got the dremel out for the other bolt. Much quicker
Finished them with some sand paper
