Is it running on both pots? Certainly seems to be fuel starvation, empty the float bowls and see that there's fuel in both, if there is check all the hoses for leaks, I have encountered a similar problem that turned out to be the vacuum tap hose leaking a bit, so the tap wasn't opening fully.
Sound like sticky chokes.
