-   -   Suzuki dealer has wrecked my bike (http://forums.sv650.org/showthread.php?t=60571)
TSM 30-05-05 09:32 PM
have you tried bump starting the bike? That should rule out any problems with the CDI unit. Have you tried to wire the starter directly to the battery to see if it is working? Does the relay click when you press the starter? If not its either the IMMO or the relay is stuffed or your starter circuit is damaged somewhere.
chutz 30-05-05 09:49 PM
just a thought but could it be either the switch in the clutch or the sidestand? I dunno about old curvy ones but the sexy pointy ones sat "chec" on the dash if either of these things is not sorted.properly(pulled in for clutch or up for sidestand)..
Cloggsy 30-05-05 09:54 PM
Suzuki GB & Trading Standards would be my next ports of call, without a shadow of doubt :!: Tossers :roll:
Quiff Wichard 30-05-05 10:01 PM
I can name and shame !!
well no I cant but being a Crewe boy !!I would say it must be
SINGLE TRACKER!! on flag lane !
always hellishly expensive and the woman there seems to rule the roost and is never helpful!
but- that is my opinion !! and I am not saying it was them ! (but it is !!)
Mike1234 30-05-05 10:23 PM
Re: Suzuki dealer has wrecked my bike
Originally Posted by gerbilion
To cut a long story short my K1 has an electrical fault, all the electrics seem to be working apart from it wont start…. :(
What happens if you short out the two connectors on the main relay/fuse thingy that sits under the front rightof the sub frame? I had exactly this problem and it turne dout to be a faulty relay. If shorting out these connectors makes the bike turn over (as it did on mine) then that's your problem.
Mike1234 30-05-05 10:25 PM
What happens if you short out the two connectors on the main relay/fuse thingy that sits under the front right of the sub frame?
tomjones2 30-05-05 10:31 PM
i'd would definaly take it up with trading standards, i'm sure that they cannot do things like that
which dealer was it?
gerbilion 31-05-05 05:58 PM
Yes it was SINGLE TRACKER in crewe and i have contact suzuki GB this morning......
And they dont want to know :!: :!: :shock: the actual words from a girl called kerry and a bloke called paulo (i called twice, once to the help line and then to main office but the calls go through the same call centre :roll: ) was that suzuki GB have no control over how their dealerships provide a service :!: :shock:
i said "what even if they are bringing suzuki's name into disripute" and they said that they are not able to do anything :shock: "if there is a problem then i have to take this up with the garage and suzuki are not willing and will not get involved"
Now this has shocked me :shock:
gerbilion 31-05-05 06:02 PM
Originally Posted by BigApe
Gobsmacked. :shock: :shock:
Seeing as you can't ride it anyway, I would have refused to have it back like that and gone straight to trading standards. I assume that you did not actually pay them anything :?:
:oops: no stupidly i was like a rabbit caught in head lights i paid for it and got out.... i was actually stunned when i got home, thats when it sunk in what had or hadn't just happened..... i just wish i had paid by credit card instead of debit card #-o
gerbilion 31-05-05 06:07 PM
Yup you got it in one and she seems to wear the trousers as when i told the mechanic that he has to put the air box and tank back on so i could get it in the van she had a pop at him and told him to get on with servicing :shock: so he trotted off to do as he was told :!: :!:
