-   -   PETROL POURING OUT? (http://forums.sv650.org/showthread.php?t=65732)
triumph5ta 31-01-06 10:20 AM
Im assuming you have a curvy model ie with carbs:
Undo the two retaining bolts at front of tank and prop it up. You will see a fuel pipe going from the fuel tap on the l/h side of the tank to the r/h side of the frame. Check that is not leaking anywhere. Ignore the short pipe from the tap to the carbs thats the vacuum pipe and does not carry any fuel. Generally check for leaks. Start the engine and check for leaks again. If its still leaking from somewhere look under the bike and you will probably see a breather pipe which is leaking fuel. Try and trace it back up to see where it comes from eg front carb or rear carb. Then report back...
If you have a fuel injection (pointy) model then the above applies but replace carb with fuel injector body...
Adam.
Quiff Wichard 31-01-06 10:50 AM
cheers adam..
it is indeed an 02 curvy
will have a look in a while.. and report back
been waiting for delivery of a new settee - (yes the one from the previous post !)
and guess what- they came when they said ! first time I waited in and not had to wait ALL day !..
I will look at me bike and let u know.
Stig 31-01-06 07:26 PM
Originally Posted by Quiff Wichard
Ok guys thanks..
I really wish I was mechanical like sid - but then I am young!!.
no serious I may have to do a night class or similar..... I am very envious of you guys that know all the technicaities and can diagnose from a description...
Hey if you owned my bike you would find out a whole lot of stuff very quickly :lol: :roll:
Quiff Wichard 31-01-06 10:01 PM
still been really busy - no time to look..will do yomoz...NO new sofa bein delivered tomoz!..it came today !!
Warthog 01-02-06 12:20 PM
when I had my ER5, it suddenly conked out mid run and I pulled over and there was petrol leaking all out of the middle of the bike somewhere. The garage picked it up and said it was just a clogged up carburettor, and it just needed cleaning, which sorted the problem. Might be that.
Disclaimer: I am not a mechanic!
Quiff Wichard 01-02-06 08:07 PM
could be
and I still noy had time an I in Birmingham all day tomoz..so it may be a 5 O 'clock look at - in me suit !! when I get in..
Peter Henry 02-02-06 07:46 AM
Quiff wrote:
in Birmingham all day tomoz.. in me suit !!
Hey mate that court date has come round quick? That will teach you to leave sheep alone!:) :) I am sure the excuse of "She made the first move." Will carry little weight! :lol:
Quiff Wichard 02-02-06 07:09 PM
JUST got in..
Mrs Q got whiff of the fact that theres an IKEA at wednesbury !!...so I had a detour with a list off her..
