Blue_SV650S |
26-08-06 08:25 AM |
Originally Posted by william t.
I still need a stiffer spring on the zx10r shock. I have got 36mm of static sag and would like to get down to around 32.
The stock ZX10 spring is ample to hold the bikes weight, therefore the static sag should be able to be taken up with the preload. Its only if you struggle with rider sag it is a sign that the spring is too weak (I'd say you have to be well over 16 stone (~220lb) for this to be a problem??).
