Did you replace the steel plates too?
What colour, thickness are they? Are they warped and blue? |
I did not replace the plates, but they did not appear warped. But I did not check to see what order I installed the plates in. Maybe I should check that. The rod IS moving, but it is just not moving enough to contact the pressure plate or the pressure plate is out too far for it too contact.
If the worm drive's gone, the lever feels heavy and pretty "crunchy", usually... You're pushing scraping metal instead of a ball-and-ramp. So, I'm kind of with the others.
Your new fully assembled clutch pack is, unsurprisingly, not the same thickness as the worn one, (which is good as there'd be no point replacing a worn one with another worn one), as the lifter only separates the plates by a few millimetres, a suitable adjustment is unlikely to remain if you were to change even one plate, let alone the whole friction set.
Do this: Quote:
I just asumed he would have done that.
Thanks for the huge response and all the help so far. |
Give or take a 5000 times or so. |
