-   -   dodgy spark plugs (http://forums.sv650.org/showthread.php?t=78739)
hovis 10-10-06 10:31 AM
the bike starts first time great then after a ride it will not start, its turning over but not starting, if the plugs were dodgy it shouldent start in the 1st place?????????????????????
andy 10-10-06 10:39 AM
Maybe, intermittent fault, always difficult to diagnose.
The SV has a known problem of the wiring loom wearing under the rear of the tank and shorting against the frame - causing all sorts of intermittent woes. Check that first, should take no more than 15 mins to check thoroughly - fix is a different story.....
hovis 10-10-06 11:22 AM
going to bypass the stand switch first :smt102
John Burt 10-10-06 12:18 PM
why i'm sure the stand switch (& clutch) just stop the starter from spinning.
