-   -   Sv Tilt Switch Help (http://forums.sv650.org/showthread.php?t=84958)
SV650Racer 04-03-07 03:10 PM
Re: Sv Tilt Switch Help
If your tilt switch hasnt been put back in the correct position it will cut out!. It needs to be facing the correct way up and vertical. If its not when you tip the bike to an angle (like off the stand) it will cut out.
Common problem i see all the time.
robbieracer 04-03-07 04:48 PM
Problem sorted. The tilt swich was in the wrong positon. Thanks for all the help. During the winter the bike had been stripped and when it was put back together it was in the wrong positon.
Thanks again
