Re: Tidying up the fur on the forks
I didn't get the blocks just wet/dry of varying grits and I did use a wet/dry block which is probably similar anyway I'm much happier now.
Dizzyblond has the problem of fur on her wheels....
On a serious note, does ACF50 work as well as advertised? |
cleaned mine up with autosol and wet and dry back end of year keep on rubbing with acf50 no laquer and still they look good would recomend acf50 anytime looks like you done a good job though toonyank:thumbsup:
So just to clarify toonyank, you got that result just by using GarryFlex blocks and lacquer? No actual repainting of the forks?
Very impressive. I will do mine when I have the forks off to redo the springs/oil. EDIT: Just spotted this - "I didn't get the blocks just wet/dry of varying grits and I did use a wet/dry block which is probably similar anyway I'm much happier now." |
Those forks look really good! Mine where quite bad when I brought the bike, my dad rubbed them down and completly repainted them (they are now the same/similar finish to a set of GSXR600-K1 forks). Its defintaly something worth doing, makes the bike look as good as new.
Matt |
After sanding them down were they repainted? They look like it they were, since i believe you get a semi shiny finish using wet and dry
I don't think they are actually painted by the factory I think it is just some type of lacquer and a thin coat at that. That's probably why everyone has trouble with the SVs that's my only complaint about Suzuki build quality so far. I've only had the bike since mid April and I haven't had the problems of corrosion anywhere else. |
Suppose they are, its on the list of things to do :smt112 |
