Old 14-12-12, 04:01 PM   #121
SV_archie99
Default Re: Accessory Distribution Gizmo Group Buy
Lance
My unit has arrived today, a very well put together piece of kit - nice work.
Will be fitted tomorrow weather permitting.
I think you should rename it:
Bibio's Accessory Distribution Gizmo Encompassing Relay -BADGER
John
Old 14-12-12, 04:06 PM   #122
yey. post office done their job.
glad you like it. if you need any help installing it just gives a shout.
nice one about the name but i don't think xXBADGERXx would be to happy
Old 14-12-12, 04:17 PM   #123
SV_archie99
Ah, yes.
Could add Switching to the name......
Old 14-12-12, 04:18 PM   #124
SV_archie99
Ah, yes.
Old 14-12-12, 06:28 PM   #125
joshwalker094
joshwalker094's Avatar
Arrived today too, looks good. Now where do I put and how do u use it haha
Once again lance superb service.
Again happy to review and leave pictures on the new site
Josh
RIP Reeder
JOSH WALKERRRRRRRRRRRR
Old 14-12-12, 06:55 PM   #126
web site will not be anywhere near ready till mid/late January. there wont be any feedback pages either as that's what this forum is for
glad you like it Josh.
again i'm happy to help you walk anyone threw the installation but its pretty simple.
turn bike off.
take seat off and lift tank.
connect the red wire eyelet of the gizmo to the + terminal of your battery then take the black wire with the eyelet and connect that to the - side of the battery terminal.
find your rear brake light switch then trace the wire till you come to a 2 way connector (its around the area of the hinge for the tank). disconnect the connectors and then connect the white connectors on the gizmo in line.
connect the supplied bullets to an accessory then plug them into one of the 3, 2 way tails.
put one of the supplied fuses in line with the tails your using.
turn bike on and be amazed that the accessory turns on at the same time then turn bike off and be even more amazed.
Old 14-12-12, 07:30 PM   #127
muzikill
muzikill's Avatar
Lift tank?. .. The fitting is all to the rear.
Old 14-12-12, 07:31 PM   #128
Tomor
Tomor's Avatar
Was just thinking that.
Yam XT125R - Sold SV650 -Sold DL 650 K6 - Sold
2012 Street Triple R - For Sale - Linky here
Tomor is offline   Reply With Quote
Old 14-12-12, 07:34 PM   #129
nope. you need to gain access to the rear brake light switch connector which is in that bundle under the hinge area of the tank on a pointy. on the curvy its on the right hand side around the same area.
where you locate the gizmo is up to you.
Old 14-12-12, 07:42 PM   #130
pointy:
curvy:
Jetpack like gizmo for flying over water.... MotorPsych Idle Banter 1 28-11-11 06:36 AM
gizmo freaks.....you got to see this. rictus01 Soho Massive 16 16-02-09 04:53 PM
Nifty little gizmo riktherider Bikes - Talk & Issues 13 14-10-08 09:41 AM
What's the gizmo Ed Bikes - Talk & Issues 3 13-07-08 10:58 PM
SOLD..... G Pack Gizmo... reggie perrin For Sale - SV's and SV related items 1 16-01-06 04:52 PM
