Old 05-01-13, 10:49 PM   #231
Default Re: Accessory Distribution Gizmo Group Buy
clever, maybe. genius, no way.
glad you like it m8
Old 06-01-13, 09:09 PM   #232
jmiller_100
Received mine yesterday as well. Just what I needed, many thanks.
Old 06-01-13, 09:17 PM   #233
Knobby
Got mine on saturday.
Whats the red wire with the two white plugs for?
Old 06-01-13, 09:18 PM   #234
Knobby
Whats the red wire with the two white plugs on for?
Old 06-01-13, 11:29 PM   #235
SIII
SIII's Avatar
Talking Re: Accessory Distribution Gizmo Group Buy
Fitted my first accessory today. Hard wired my phone/sat-nav power supply using the gizmo. the unit came with a 2 Amp fuse, so I just cut that off, put fuse into gizmo and fitted the connectors supplied with gizmo.
Phone powers up when ignition switched on! Cheers Lance, job's a good one!
"You know, Scotland has its own martial arts. Yeah, it's called Fuk-U. It's mostly just head butting and then kicking people when they're on the ground"
The Stoppy King
SIII is offline   Reply With Quote
Old 06-01-13, 11:41 PM   #236
you mean the orange wire with the two white plugs. this connects in line with your rear brake light switch to activate the coil in the relay so it turns on and off with the bike. if you don't connect this then the gizmo wont work.
just follow the rear brake light switch wire till you find the same type of connector then separate the plug then plug the gizmo connectors into either end.
yey. but does the phone power off when the gizmo does
nice one SIII glad you like it.
Old 06-01-13, 11:46 PM   #237
SIII
SIII's Avatar
Yep, works a treat. Powers up and switches off with the ignition key.
I've pulled the other 2x 5 Amp fuses out of the unit at the moment, cos I ain't using them yet. Was going to use one of the feeds for my Stebel horn power supply, but it works well as is - so decided to not fix whot ain't broken.
The Stoppy King
Old 06-01-13, 11:57 PM   #238
would make it neater i suppose
my plan of action will be a lights off till start unit which will have a feed for the relay coil on the gizmo so the gizmo wont start till the start button is released so no power drain when you turn the ignition on.
a powerbox to feed live power to 3 components e.g. gizmo, horn and HID.
Old 07-01-13, 12:51 AM   #239
LewSpeight
LewSpeight's Avatar
I like that idea, but sometimes when with friends or whatever i like to have the lights on without the engine so we can gather round and talk in the dark, good thinking though.
How soon will you be doing this powerbox? i'm wanting HID's within about 5 weeks?
Old 07-01-13, 01:08 AM   #240
will be putting in an order for more connectors (i have run out again) tomorrow so should have them done by the end of the week. i have the cable and boxes here.
if you do install HID then they don't like being turned on-off-on again and can reduce the lifespan considerably.
the pointy from k5> has an auto cut while starting in the circuit but the lights are still turned on with the ignition then they are turned off when the starter button is pressed then back on again when you let go of the starter button which is bad for HID
K3-4 are always on with ignition and stay on while starting which has no ill effect on HID.
Jetpack like gizmo for flying over water.... MotorPsych Idle Banter 1 28-11-11 06:36 AM
gizmo freaks.....you got to see this. rictus01 Soho Massive 16 16-02-09 04:53 PM
Nifty little gizmo riktherider Bikes - Talk & Issues 13 14-10-08 09:41 AM
What's the gizmo Ed Bikes - Talk & Issues 3 13-07-08 10:58 PM
SOLD..... G Pack Gizmo... reggie perrin For Sale - SV's and SV related items 1 16-01-06 04:52 PM
