Old 23-03-13, 03:03 PM   #291
muzikill
muzikill's Avatar
Default Re: Accessory Distribution Gizmo Group Buy
Originally Posted by Tomor View Post
Muzi, here's a link to my Dropbox which should give you an idea o what to look for. It's the white connector with the orange wire coming out of it. Sits just infront of the tank (tank removed in all the pics)
https://www.dropbox.com/s/6dsl48jzvu...%2020%2043.jpg
Tom
Ta dood, but i aint seeing anything like that under the K3 sv650s tank the only thing i have that resembles the right size connector is this. Checkout the colours of the wires going in/out because the book of lies doesn't have some of them in the wiring diagram eg. white with green dashes. As a desciption, the left of the picture wiring ( white/green dash & black white lined / green dash) goes to the rear & the white & green wires are coming up from the loom around the fuel pump connector area where the loom junctions across to the rotor & rear brake pedal switch.
like bibio said, it aint rocket science but this is doing my nut in as i dont want to power it up & find something goes 'pop'
Old 23-03-13, 04:30 PM   #292
try again... that's is the side stand cut out switch.
there is a spring connected to your brake pedal follow this up till you reach the switch then follow the wiring till you come to the connector.
Old 23-03-13, 04:39 PM   #293
Tomor
Tomor's Avatar
Default Accessory Distribution Gizmo Group Buy
As bib said, if you can't find the connector, trace the brake switch back up the cable. You don't want to blow something trying to save time!! Good luck!! Haha
Yam XT125R - Sold SV650 -Sold DL 650 K6 - Sold
2012 Street Triple R - For Sale - Linky here
Tomor is offline   Reply With Quote
Old 23-03-13, 10:38 PM   #294
muzikill
muzikill's Avatar
Default Re: Re: Accessory Distribution Gizmo Group Buy
Those wires disappear into the loom. I (really) hope the alarm installer didnt cut up that part of the loom.
Old 23-03-13, 11:18 PM   #295
no the alarm fitter would not have spliced the brake switch into the loom .... keep looking. there WILL be a connector between the main loom and the switch.
Old 24-03-13, 10:09 PM   #296
Winder
Winder's Avatar
Hi, i would like one of your fine electrickery gadgets please Mr Bibio. Also i would like another set of the adjuster plates (non scotoiler). Please let me know how to make payment.
Old 26-03-13, 06:04 PM   #297
see here: http://forums.sv650.org/showthread.php?t=188926
@ Winder. send me a PM of what you want.
same goes for other peeps.
Old 29-03-13, 01:57 PM   #298
Knobby
I am liking my gizmo thingy muchly.
I like that I can have my sat nav on a charging and if needed my heated grips.
Old 29-03-13, 02:36 PM   #299
excellent. but you forgot the best bit.. you dont have to remember to turn things off when you park the bike up
Old 31-03-13, 01:42 PM   #300
muzikill
muzikill's Avatar
That isnt the sidestand connector this green connector is....
Heres a better pic although im lost figuring out what it does in the alternator. The bottom connector has 3 black cables which matched up with the haynes wiring diagram but i dont know wtf the green & white does.
There is absolutely no connector from the rear brake switch
From this end it goes underthe fuel tank & straight into the loom where it must be spliced with the front brake switch. Im wondering if the plug i was going to use will still have a ignition only active live that will do the same job. or could i cut off the connector & jam in the cable along with the rear brake fuse in the fuse box which would do the same job?
Jetpack like gizmo for flying over water.... MotorPsych Idle Banter 1 28-11-11 06:36 AM
gizmo freaks.....you got to see this. rictus01 Soho Massive 16 16-02-09 04:53 PM
Nifty little gizmo riktherider Bikes - Talk & Issues 13 14-10-08 09:41 AM
What's the gizmo Ed Bikes - Talk & Issues 3 13-07-08 10:58 PM
SOLD..... G Pack Gizmo... reggie perrin For Sale - SV's and SV related items 1 16-01-06 04:52 PM
