Old 24-02-09, 11:10 PM   #11
theshed
Default Re: clutch
nice bit of info what really impresses me is the way people on this forum help each other and shares their knowledge so even an igmaranus like me can feel that if i just have a go and things fail there will be help there
great
Old 24-02-09, 11:33 PM   #12
anna
anna's Avatar
Default Re: clutch
What's allover your chain btw anna? Is that salt?
Itīs chain lube ..."A.R.S. LUBE" ... not that kind you pervs
Itīs not a scott oiler .. YET .. thatīs a fix for another day.
BTW as a side note a common big no no, is some big muscles doing bolts up "super tight" .. unless it requires a set torque itīs not necessary to do bolts up to test your muscles .. this only strips threads and makes you a numpty!!
Old 28-02-09, 12:59 PM   #13
Lucas
Default Re: clutch
Is 6 to be positioned as low as possible and moved up as cable is stretched beyond lever adjuster range?
Old 28-02-09, 04:30 PM   #14
Stingo
Stingo's Avatar
Default Re: clutch
Just done my clutch too. Tried the same method a la squid anna et al...but when I screw in the screw and move it out a tad then adjust the cable tension etc then start up the bike and put it in gear, it just stays disengaged so I end up turning the screw back out about 2 whole turns so that the engine actually does something...like engage with the gears...if that makes sense...
Twitter: @poseidon_ashore
Old 28-02-09, 07:34 PM   #15
Dave20046
Dave20046's Avatar
Default Re: clutch
I wouldn't mess with the screw with the engine on. Did you loosen everything off before touching the screw?
Old 28-02-09, 10:00 PM   #16
Stingo
Stingo's Avatar
Default Re: clutch
I didn't do it whilst the engine was running. Stuff was all loosened prior to adjustment.
Did the adjustment (screwed it in and then out a tad) - fiddled with cable adjusters to tighten cable, started engine, selected first, let out clutch, bike went nowhere.
Turned off engine. Repeated above but unscrewed the little screw a bit further and so on.
Repeated about three time until the gear finally bit...
Old 01-03-09, 12:18 AM   #17
rictus01
rictus01's Avatar
Default Re: clutch
Very nice Anna, should help a few folks out.
Cheers Mark.
Old 01-03-09, 12:53 AM   #18
anna
anna's Avatar
Default Re: clutch
I have edited first post to include a better description for this..... go take a look and let me know if it still doesnt make sense.
Old 01-03-09, 11:18 AM   #19
steveg
steveg's Avatar
Thumbs up Re: clutch
Thanks Anna great How to
Cheers Steveg
ex - red sv650s 06 reg
Now Triumph sprint 1050 ABS 05 Reg
AKA Papa Smurf
steveg is offline   Reply With Quote
Old 01-03-09, 12:35 PM   #20
Lucas
Default Re: clutch
Thanks Anna!
installing new clutch cable tomorrow, very nice to have black and white advice, the job will now be done with ture craftmenship
Adjusting clutch lever cable - help please TC3 Bikes - Talk & Issues 1 09-05-10 04:06 PM
Adjusting clutch play lawriejones1 SV Talk, Tuning & Tweaking 8 01-12-08 09:10 PM
Adjusting Clutch Cable tonybmw92 SV Talk, Tuning & Tweaking 2 08-08-08 04:00 PM
Adjusting Clutch echomadman SV Talk, Tuning & Tweaking 5 16-05-05 03:41 PM
Adjusting clutch on sv650s? mordecai SV Talk, Tuning & Tweaking 3 29-03-05 04:39 AM
