#11 |
For 30 Id be in!
#12 |
You need to be able to dismantle the forks, drill out some holes in the damper rods and block a small hole up with e.g. epoxy. If fitting to a pointy, you also need to get a bush machined and fitted to the end of the damper rods to keep the emulator centralised so it seals properly. No bush is needed on a curvy.
#13 |
I'm in!
#14 |
Whats the diff on a pointy? Eg. Against new springs better thicker oil against factory springs?
Oh and the 'knock' Because id be in if someone can do the spacers and it will get rid of the knock. It will be my next project.
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ![]() K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. Last edited by muzikill; 21-03-13 at 10:28 PM. |
#15 |
I am offering mods to rod and spacers fitted to suit these debrix in pointy, £40.
Also modded rods for curvy £30. Plus post. Can send some modded ones out so long as you send me your OEM ones back when you've swapped them. Might be a slight issue if a lot of people want them doing at the same time (i.e when the emulators land!) I also get a slight discount on Ktech springs so if people wanted the option of a full package sending, springs, oil, emus and rods then it can be sorted.
#16 |
How often do these come up? My bike is still new, and I'm still a new rider so don't think I'd get that much advantage from them. But if they don't come up that often it I may get hold of a pair and can keep them until I'm ready to do the springs, heavier fork oil and emulators at the same time.
#17 |
Chris, what sort of price would the full package be for a pointy?
Cheers |
#18 |
muzikill - I dont have them but seperating low and high speed has to improve handling and indeed seems to from all the anecdotal evidence. Do a search and read a few threads and see what you think.
SvNewbie - The last group buy was around this time last year but i couldnt say for sure how often these things happen it would need a motivated individual to arrange it all. Also you are prob never too new to riding to have sorted suspension. It makes a bike nicer to ride and gives you more confidence. In my opinion its safer also. The way the SV handles rough surfaces whilst cornering isnt ncie at all and apparently these should help lots with that. So list is :- gt900uk Richardah Safekyle R0ddy Anyone else please copy the list into your post and append your name to the bottom. Thanks |
#19 |
Is there a cut off date as to when they'll be ordered?
#20 | |
£80 springs £10 oil £40 damper rod mod £30 emus (tbc) postage of lot £10? I've done them before for folk where they've sent me complete forks, can usually have them back with you within a week.
Now rebuilding a 63' fishing trawler as a dive boat Last edited by yorkie_chris; 24-03-13 at 05:46 PM. |
Debrix Cheap Emulator Group Buy. | Epic Monkey | SV Talk, Tuning & Tweaking | 80 | 22-03-13 11:40 AM |
Debrix Emulator | gt900uk | Stuff Wanted | 6 | 21-03-13 05:42 PM |
My Debrix emulator settings. | peeterus | SV Talk, Tuning & Tweaking | 4 | 09-06-12 05:13 PM |
Debrix Cheap Emulator Group Buy Take 2 | Dipper | SV Talk, Tuning & Tweaking | 164 | 02-04-12 11:50 PM |
Debrix Cheap Emulator Group Buy Take 3 | takracing | SV Talk, Tuning & Tweaking | 7 | 17-03-12 12:30 PM |
