#11 |
Thanks for posting that up, will be useful for quite a few of us.
Are those the new safety steel toe capped kevlar socks your wearing ![]()
Black naked 1999 sv650 which im trying to keep happy Custom paintwork Saragon Customs Spray painting Electrical fault finding guide and Regulator rectifier test Only a biker knows why a dog sticks his head out of a car window. |
#12 |
Then you will have added the thickness (height?) of the emulator as preload which may be way too much. All depends whether or not your preload was set adequately before starting, only way to check properly is measure the static/rider sag etc then adjust spacers to suit.
#13 |
So how does the cutting of the spacers work on curvys with no preload adjusters?
#14 | |
So adjusting a preload adjuster by winding it in 5mm has the exact same effect as replacing the spacer with one 5mm longer. |
#15 | |||
![]() ![]() Quote:
![]() Actually, one downside is that with the front well on the way to being sorted it's highlighted just how immensely sh*te the rear is... gotta get that zx6r shock in over easter too, yay ![]() Quote:
![]() ![]() Last edited by 85jas; 03-04-12 at 02:36 PM. |
#16 |
Didn't cut mine either. Stuck the spacer in first, then washer and spring. No change to overall spring preload.
Formerly known as Gajjii Previous Bikes: Red Sk1 Curvy, Red MT-07. Current Bike: Black MT-09. |
#17 |
Think about it, you've added all the original parts back in with an additional thickness of emulator. If the emulator is 20mm (not sure on its actual dimension) then you have added 20mm of additional preload.
#18 |
Haven't, the spacer when put in first slides around the emulator and rests against the top of the damper tube.
#19 |
#20 |
The spacer is the tube at the top of the assembly, it sits on top of the main fork spring on top of a steel washer.
Are you talking about a separate component? |
Debrix Cheap Emulator Group Buy. | Epic Monkey | SV Talk, Tuning & Tweaking | 80 | 22-03-13 11:40 AM |
Debrix Cheap Emulator Group Buy Take 2 | Dipper | SV Talk, Tuning & Tweaking | 164 | 02-04-12 11:50 PM |
Debrix Cheap Emulator Group Buy Take 3 | takracing | SV Talk, Tuning & Tweaking | 7 | 17-03-12 12:30 PM |
Debrix damping emulator questions | bigchris | SV Talk, Tuning & Tweaking | 13 | 13-07-11 02:08 PM |
Inforad installation advice for curvy SV | Lucas | SV Talk, Tuning & Tweaking | 21 | 18-03-09 11:06 AM |
