Old 03-04-12, 06:48 PM   #21
Grant66
Grant66's Avatar
Default Re: Debrix emulator curvy installation pictures
The spacer was above the spring (pre emulator), its now below the spring.
Couldn't see a good reason why it wouldn't work the other way round. Seems to.
Formerly known as Gajjii
Previous Bikes: Red Sk1 Curvy, Red MT-07.
Current Bike: Black MT-09.
Grant66 is offline   Reply With Quote
Old 03-04-12, 06:50 PM   #22
flymo
flymo's Avatar
So what is holding the emulator in position?
Old 03-04-12, 06:56 PM   #23
Lol. Think about where the fluid pressure is acting and what that will do.
You've got £40 worth of pretty brass fork oil shaker...
Have you not noticed the complete absence of any comp damping now the holes are (presumably) massive and the emulator doing nowt?
Old 03-04-12, 07:32 PM   #24
Grant66
Grant66's Avatar
Doh! Strangely it seemed better.
Didn't think that through properly.
Better have another go.
Old 03-04-12, 11:18 PM   #25
Winder
Winder's Avatar
Top tip for damper rod bolts. You can get a 12v impact wrench/gun for about £20 on flea bay with crocodile clip connectors for putting straight on a battery. Works a treat
Old 05-04-12, 10:07 AM   #26
peeterus
just for the records, on one of my valves, the rebound washer spring had not any preload, so that the washer did not really seat against the top, i just stretched the spring tll the washer was just protuding the lower body
Old 05-04-12, 11:05 AM   #27
flymo
flymo's Avatar
Why didn't you just wind in the adjuster to take up any slack first? Then add 2 1/2 turns as described?
Old 05-04-12, 11:59 AM   #28
Sy-superfly
Just one note to the "pretty oil shaker" if the spacer is still above the emulator it should still work as the emulator is still forced onto position ontop of the damper rod, unless I've read this wrong. The only cause for concern is the width of the spacer material isn't to small and cuts into the emulator. The spring ontop will still compress the spacer down, which in turn pushes down on the emulator I would have thought. If he put the spacer between the emulator and rod then you'd have a very pretty oil shaker.
Old 05-04-12, 12:03 PM   #29
Sy-superfly
Ow boll&@£x ,did just read the "WHOLE" post again the spacer is too big to sit on the emulator and goes over it. Teach me to only read the last page.
Old 05-04-12, 12:04 PM   #30
flymo
flymo's Avatar
Grant66 described that the spacer was actually bigger than the outer diameter of the emulator and so did not restrain it.
No point in ar$ing around with the position of these parts, best to fit them as they were intended.
Debrix Cheap Emulator Group Buy. Epic Monkey SV Talk, Tuning & Tweaking 80 22-03-13 11:40 AM
Debrix Cheap Emulator Group Buy Take 2 Dipper SV Talk, Tuning & Tweaking 164 02-04-12 11:50 PM
Debrix Cheap Emulator Group Buy Take 3 takracing SV Talk, Tuning & Tweaking 7 17-03-12 12:30 PM
Debrix damping emulator questions bigchris SV Talk, Tuning & Tweaking 13 13-07-11 02:08 PM
Inforad installation advice for curvy SV Lucas SV Talk, Tuning & Tweaking 21 18-03-09 11:06 AM
