#91 |
AWESOME thread.
Kuku AWESOME work. Seriously wicked. 110%. Please keep posting pix and progress! Best of luck!! PS your matt black painted frame and parts could only make me think of: http://entertainment.howstuffworks.com/batmobile8.htm Last edited by williamturner1; 08-04-10 at 02:37 PM. |
#92 |
#93 |
#94 |
#95 |
Those made of alloy?
#96 |
Omg you must have spent a masive amount of money on this !!!! Can i ask what you spent so fare>>>?
#97 | ||
Brake discs full set (China) - 142.00 Brake lines full set (UK) - 65.00 Brake calipers dust and seal kit (UK) - 65.00 "Ohlins" front forks springs (UK) - 62.00 "EBC" HH Syntered full set (UK) - 60.00 "GSXR 600-750" K4/K5 Wheels, Front fender, Rear shock (USA) - 140.00 Seat cowl (UK) - 32.00 "K&N" (USA) - 45.00 Frame crash protectors (I think these are made in China, but i purchase them from USA) - 20.00 4 LED indicators (China) - 20.00 Paint for frame, tail, swingarm, wheels, clip-ons, triples (BG) - 100.00 New custom top triple (BG) - 30.00 Rearset plates (BG) - 31.00 ("Valter Moto" rearsets are actualy free, because I bought all crashed CBR-919 for 100.00 and sell it to spares, but keep the rearsets for me.) Wheels repair before painting (BG) - 40.00 Service for fron end (BG) - 50.00 (including seals, oil and changing front springs). Gas tank straightening and primer (BG) - 22.00 Paint spray, sand paper, diluent and so fo painting the bike (BG) - 30.00 Rizoma grips (RO) - 27.00 "Yoshimura" end can (USA) - 44.00 Radiator from old model "SV" (UK) - 79.00.... not sure about this price ![]() I'm sure that I've miss something, and that's why let me answer to your question - "About GBP 1500.00" ![]() The bike cost me about GBP 2000.00, with GBP 300.00 for registration, taxes and servicing. Besides that, I bought a lot of parts, that I can't use, because they won't fit to the bike... like "Ohlins" rear shock spring, which is too short for original "GSXR" shock ![]() Or a "GSXR" rear hugger, which won't fit to the "SV" swingarm ![]() In my longing for quick modifications, I make some mistakes.... and I'm selling this parts right now ![]() I also must buy: New (aluminium and welded) brackets for old model radiator - 30.00 Radiator cover - 30.00 Chain and sprockets - 100.00 Tyres - 150.00 Disc bolts - 10.00 Cush drive for rear wheel - 10.00 Of course, rear wheel swap, machining, spacers and so - max 60.00 If I can find another rear shock for "no cut the battery box" change - 100.00 Front and rear axle crash protectors - 30.00 Bar ends - 20.00 Headlight from "Yamaha MT-03" - 60.00-70.00.... I hope ![]() "Ohlins" steering damper in reasonable price - 70.00 Engine oil and oil filter - 50.00 Completely new, custom made exhaust system (without end can) - max 100.00 with the help of my old friend exhaust-shop. Some other small parts..... TOTAL amount, in finish line, will be about a GBP 4500.00..... which is the price of the new "SV650", but mine will be some kind of unique, especially in Bulgaria, and most important - made by my self ![]() |
#98 |
Good job mate!, just one question, how do you plan to fix the yoshi exhaust??
#99 |
Thanks, Rammsteinkid
![]() I don't know yet, but will think of it when the exhaust is ready. Today I repair the "Yoshimura", but it's not ready, because I don't have the end straps and badge. Drill the rivets. ![]() Push the rivets in. ![]() Unstick the caps. ![]() Cut the cap (bottom) from damaged side of the can. ![]() Cut a little bit of outer pipe on the top, because there is tiny scratches too. ![]() And pull up the outer pipe to fit the upper cap again. ![]() So, the upper end is now fixed. Cut the outer pipe of the bottom to make easy work with internal materials. ![]() Must look like this.... ![]() Cut the wadding and wire-thing. ![]() ![]() ....and the internal pipe. About 5mm. out of the outer pipe, to match the cap. (Not nessesary 5mm. - depends on the end can cap). ![]() Before put the cap back, must remove the internal pipe left over. Careffuly! Don't dent the cap like I did ![]() ![]() Remove all with thin pliers. ![]() Must look like this. ![]() Now putting back the cap. ![]() ![]() ![]() In ![]() ![]() The mid pipe. ![]() Must file down the moustaches. ![]() And the final result ![]() I hope with new straps and badge to be more beautiful. ![]() I make it exactly 30cm..... an absolutely chance ![]() ![]() Now I have a question - can I polish/varnish this carbon fibre? I clean it up, but nothing happens. I don't know why (from exhaust heat or sunburnt), but you can see on the pictures that it's look like it's older than me ![]() |
#100 |
Great work on the pipe. Wondering if this had escaped your attention.
I've never seen anything like it on an SV. Enjoy. Ebay UK Item No: 110518643391 |
650R Launched in March | Dal | Bikes - Talk & Issues | 66 | 15-05-06 06:18 PM |
Bike Test USA - ER6 (Ninja 650R) vs SV650 | SV650S_DUB | Bikes - Talk & Issues | 3 | 10-05-06 03:55 PM |
