Old 12-06-10, 10:00 PM   #151
barwel1992
Default Re: Gsvxr-650r
thats not a bad way of mounting the vapor might look in to it my self
Old 14-06-10, 07:04 PM   #152
Kuku
Sprockets.... GBP 35,00 delivered.
15/47 - 520
Old 20-06-10, 10:05 PM   #153
Kuku
Hi guys,
yesterday I mount the speedo sensor.
Just need to put the magnet in the hole.
Because the speedo sensor cable makes U-turn to go up, I must secure them twice.
You can see that the front fender is in.
And the front end is almost ready.... just need to change the bearings and bleed the brakes.
Grips, switches, mirrors.
Bar and weights..... still think to paint them or not
Old 20-06-10, 10:45 PM   #154
barwel1992
hi mate, regarding you throttle cable problem mine are routed through the right hand side (as you sit on the bike) yours look like they come from the left ?
Old 20-06-10, 10:59 PM   #155
Kuku
Hi Dan,
yes I saw few bikes with throttle cables like yours - must try this!
Really don't know what to do with this tighten throttle cables....
Old 20-06-10, 11:01 PM   #156
barwel1992
mine were like yours, but when i put them through the other side it freed up about 5cm of cable, maybe enough to make ures work
Old 20-06-10, 11:06 PM   #157
Kuku
I surely will try this.
Thanks a lot!
Old 20-06-10, 11:07 PM   #158
barwel1992
no problem
Old 28-06-10, 05:45 PM   #159
Kuku
Hi guys
Barwel, I fix the problem with throttle cables with.... (attention!!!).... changing the Rizoma grip
With usual GSXR throttle tube, there is absolutely no problem with this throttle cables!
I'm currently in progress of choosing the grips for GSXR throttle tube - "Renthal" or "Progrip" in firm compound.
Meanwhile, last week I connect the "Vapor" power wire to the battery.
Left hand sided (red-black wire), in the same way that goes stock wiring harness.
RPM wire (red wire) connected to the rear cylinder coil, which is on right hand side of the bike.
Ground for RPM is on the engine, where is the main ground of the bike.
From coil, along the rectifier-regulator, to the front of the bike.
Temperature sensor (still wating the radiator).
Also receive a few more parts....
Chain.
Oil filter with magnetic drain plug.
Side radiator covers from "Kawasaki ER5".
Need paint.
Fork adjusters.
Old 28-06-10, 06:47 PM   #160
hindle8907
hindle8907's Avatar
u not finished yet ??? lol
650R Launched in March Dal Bikes - Talk & Issues 66 15-05-06 06:18 PM
Bike Test USA - ER6 (Ninja 650R) vs SV650 SV650S_DUB Bikes - Talk & Issues 3 10-05-06 03:55 PM
