Old 15-11-09, 08:33 PM   #51
Default Re: Gsvxr-650r
Revalve it if you want it to work perfect, but then you need to replace nitrogen.
Old 15-11-09, 08:52 PM   #52
Kuku
I can't do this in Bulgaria
Not me, of course, but the mechanics and technicians didn't have the proper equipment.... or they have some, which is better to say they don't have
I measure the "Gubellini" spring and it didn't fit to "GSXR" rear shock, it's only 14,5cm., or I must use teflon sleeve
Old 16-11-09, 03:34 PM   #53
Kuku
Today I found (by the hard way) that the "SV" rear sprocker carrier and especially the rear sprocket didn't fit to "GSXR" rear wheel at all....
I also found in PazzoRacing site that the "GSXR-600/750" K4-K5 Brake lever are interchangeable with next years "GSXR", "ZX-6R" 05-06 and "Daytona 675". Clutch lever will fit from all "GSXR-600/750" 2000 to 2005 and "GSXR-1000" 2000 to 2004..... or this is only for Pazzo?!
Old 16-11-09, 03:43 PM   #54
If pazzo is same then OEM should be same too. SHOULD be, not definite
Old 16-12-09, 09:10 PM   #55
Kuku
Hi, guys
I dig out the thread, because i take some parts from painting.
Frame.
Swingarm.
Tail.
The collor is black metallic.
I also bought one "Ohlins" rear spring, which unfortunately is too short for "GSXR-600" K5 rear shock - "Ohlins" spring is 160mm. and original spring is about 190-200mm.
....and a pair of brand new "Ohlins" front springs
Old 16-12-09, 09:12 PM   #56
Rate is more important than brand with spring.
What do you weigh?
Frame looks good, even if it is wrong shape
Old 17-12-09, 08:53 AM   #57
Kuku
93 kilograms or about 205 pounds.
I try to find out spring rate for this part number 08656-10/1476 but unsuccessfully.
Old 17-12-09, 09:05 AM   #58
Alpinestarhero
Kuku, looking good shame about the spring, can you get a refund and find the correct size spring?
Old 17-12-09, 09:15 AM   #59
Kuku
I bought spring from Ebay and it's difficulty to ship back and wait for refund - I'll try to sell it here next season.
Old 17-12-09, 10:30 AM   #60
Look on top of spring, they sometimes etch it into top. I think ideal for you would be .9kg/mm at guess.
What is stock rate in those forks?
650R Launched in March Dal Bikes - Talk & Issues 66 15-05-06 06:18 PM
Bike Test USA - ER6 (Ninja 650R) vs SV650 SV650S_DUB Bikes - Talk & Issues 3 10-05-06 03:55 PM
