Old 12-08-10, 09:05 AM   #111
Default Re: What would you like to see made for the SV?
http://www.factorypro.com/products/covers.html
Old 18-08-10, 12:17 AM   #112
independentphoto
Apologies if this duplicates an earlier post but I read through them before and don't remember seeing anything.......
How about replacement foot brake and gear selector pedals (only) with roller bearings to fit the original shafts on the OEM plates/hangers? The fibre bushes can swell and interfere with the mechanism. I suspect that nice smooth bearings would make both pedals feel much nicer.
Cheers,
Garry
Old 18-08-10, 07:08 AM   #113
CodeJACK
Brake caliper adapters to allow fitting calipers from other biker than Suzuki.
Adapter that would allow fitting Brembo calipers of some kind
I dont know if there is a standard caliper mount size where you could make one adapter that would suit a range of calipers.
Front and rear of coarse.
CodeJACK is offline   Reply With Quote
Old 18-08-10, 08:06 AM   #114
There is already an adaptor to fit brembo rear one
And adaptors to fit front ones... new forks
Old 18-08-10, 08:53 AM   #115
independentphoto
Is that a deep socket "adaptor" for the Abba stand Chris?
Old 18-08-10, 09:29 AM   #116
CodeJACK
Links to site for purchase please ?
Old 18-08-10, 10:07 AM   #117
barwel1992
i have front brembo's if you need some measurements not sure how far away i am from Mat's though
Old 18-08-10, 11:58 AM   #118
Matts-Yokes
Pretty far, i think about 120miles. I would need to have an SV in the shop and the caliper to work out spacings etc. But its not hard to do, just a bit of time and SV lending required
Old 19-08-10, 03:37 PM   #119
CodeJACK
How about an affordable steering damper mount kit?
One that mount an Ohlins stype damper to the top of the right fork leg using the top yoke bolts as a location for one part of the mount and then the the two tank mount boltscould be used as the second part of the kit to support the damper itself?
you could even make this part with to space out the tank from the frame to allow more air in?
Just a mad idea as I know the SV does not "REALLY" need a steering damper
Would somehting like this even work?
Old 19-08-10, 07:36 PM   #120
www.ebay.co.uk
read here
http://forums.sv650.org/showthread.php?t=144453&page=3
Have I made it? Luckypants Idle Banter 12 02-09-09 04:25 PM
Has anyone made home made abba stand adapters? monkey Bikes - Talk & Issues 9 31-03-09 10:00 PM
He made it. Stig Thames Valley 23 17-04-08 12:44 PM
Anyone made a will ? stewie Idle Banter 32 18-02-08 02:12 PM
Something that made me think... Baph Idle Banter 24 05-01-07 09:05 AM
