18-06-09, 10:56 AM | #1 |
Alternative shock for SV650
Hiya peeps
Does anyone have a list of the years / models of gixxers that can have their shocks transplanted onto an SV? I dont really want to buy the wrong one if I can help it! cheers |
18-06-09, 11:32 AM | #2 |
Re: GSXR rear shock
Have you serached the forum yet?
otherwise I claim first "Hitler question" comment! |
18-06-09, 11:45 AM | #3 |
Re: GSXR rear shock
Yes I have but there's no definate list....
Was half expecting some sarcastic high horse comment about "this has been done over and over again" well forgive me but I thought this was the advice section of an SV forum |
18-06-09, 11:57 AM | #4 |
Re: GSXR rear shock
I don't think there is a definitive list, but this table shows a lot of options...
Here is the latest incarnation of the shock table.... YEAR MOTORCYCLE LENGTH SPRING ===== ========= ===== ===== 01-03 GSXR600 325.5mm 325# 96-99 GSXR750 345mm 375# 97-00 GSXR600 375mm 375# 00-03 GSXR750 325mm 400# 04 GSXR750 332.5mm 408# 04 GSXR600 332.5mm 425# 01-02 GSXR1000 329.5mm 430# 03-04 SV650 330mm 430# <<<==== stock 2nd gen... 05 GSX-R 1000 332.5mm 450# 03-04 GSXR1000 332.5mm 480# 99-02 SV650 337mm 510# <<<====stock 1st gen 04-07 ZX10R 338mm 540# 03-04 ZX6R(636) 340mm 540# 99-03 GSXR1300(Busa) 330mm 700# Now from the above you can see that standard pointy shock is 330mm long and has a 430 spring. It is generally accepted that if you weigh over 11st then the standard spring is too soft and something firmer is better. So pick a chock from the table with close to correct length and close to a good spring rate for your weight. HTH |
18-06-09, 12:09 PM | #5 |
Re: GSXR rear shock
Thats perfect....thanks loads
18-06-09, 12:12 PM | #6 |
Re: GSXR rear shock
I used the search to find the table, it usually shows up in most rear shock threads. Used 'shock' and 'table' as search terms and displayed the results as posts rather than threads.
I have sorted this copy of the table by spring rate though. |
18-06-09, 12:15 PM | #7 |
Re: GSXR rear shock
This is useful - thanks
Mods - worthy of a sticky I'd say |
18-06-09, 12:15 PM | #8 |
Re: GSXR rear shock
the 05 GSXR 1000 shock is the nicest fit as its closest to standard but better spring rate etc
18-06-09, 12:20 PM | #9 |
Re: GSXR rear shock
Was also wondering what other big lads (15st plus) have used. A 01-02 GSXR1000 shock looks like a winner to me!!
Have got Maxton front shock internals but unfortunatley the budget doesnt stretch to a Maxton rear shock (not a new one anyway) cheers folks |
18-06-09, 12:32 PM | #10 | |
Re: GSXR rear shock
If your Maxton springs in your forks were matched to your weight, then the 03-04 would probably be a better match, because Maxton set up is pretty firm. You could of course ring/email Maxton, they are quite helpful on this stuff.
"Your Viffer sounds like it is raising hell! Spot on." - Witchery 17/4/08 Snow Plough Appreciation Society - Member #3 Last edited by Luckypants; 18-06-09 at 12:33 PM. |
SV650 K6 shock & GSXR1000 K4 Shock | weecorey | For Sale - SV's and SV related items | 0 | 03-05-09 08:02 PM |
Brand new Nitron Shock for SV650 S 03 -06 | danf1234 | For Sale - SV's and SV related items | 5 | 25-06-07 12:33 PM |
Ohlins Rear Shock for SV650 | speedking | For Sale - SV's and SV related items | 6 | 21-02-07 10:22 PM |
Fitting Alternative Shock | Jimmy2Feet | SV Talk, Tuning & Tweaking | 2 | 27-10-06 02:13 PM |
Busa shock on an '06 sv650 naked | alabaster | SV Talk, Tuning & Tweaking | 3 | 25-08-06 06:18 AM |
