Old 29-03-07, 03:52 PM   #1
Nekkid
Default R6 twist grip. Again and again and again....
Hi folks,
Getting the bike ready for summer and was wondering about this. I'm replacing the throttle cables anywayn is it just a case of buying a throttle body and swapping it out? Any particular year of R6 go best for the curvy sv?
Any advice appreciated, thanks!
Old 29-03-07, 04:08 PM   #2
Blue_SV650S
Default Re: R6 throttle body upgrade
Originally Posted by Nekkid View Post
Hi folks,
Its the actual tube you want, to save any confusion, order this part from Yamaha 5SL-26240-00-00
Old 29-03-07, 06:28 PM   #3
Nekkid
Well, you can't get more specific than that!! Thankyou!
I assume from your knowledge you've done this to your bike, is it really just the tube I need? No other bits and bobs at all?
Old 29-03-07, 06:49 PM   #4
zunkus
I know there's a thread somewhere here about this mod but I just can't find it. I've been asking the local Yamaha dealer about this part but he hasn't replied yet. I've just sent another email right now to check on price. I was told the grips are slightly thicker than SV's which suits me fine. You might want to take this into consideration if you've got small hands.
Old 29-03-07, 07:04 PM   #5
NedSVS
This was the part number I used and it came with a grip fitted the other part number is the matching left hand grip:
5SL-26240-01-00, comes with a grip
4YR-26241-02-00 Grip L/H
Old 29-03-07, 07:17 PM   #6
Blue_SV650S
Yep the part number I gave is the only part you NEED for the mod on a curvy Then just adjust the cables accordingly ...
You will be adjusting the cables correctly anyway as you are fitting new ones!
If you like you can fit the matching LH grip as mentioned, but to be fair there is nothing wrong with the Yammy one I took mine off anyway as I was fitting heated grips
Old 29-03-07, 07:28 PM   #7
zunkus
Thanks for the left hand grip number Ned. So are you happy with the mod. Worth doing or what?
Old 29-03-07, 07:35 PM   #8
hovis
im happy with it
Old 29-03-07, 07:51 PM   #9
zunkus
Is the bike more prone to jerkyness now? You have better hand to throttle response I guess? Sometimes a full hand twist is not enough to open full throttle on stock, this mod solves this right?
Old 29-03-07, 10:05 PM   #10
NedSVS
I think this is a small but worthwhile improvement. It won't set your world on fire but it will save your wrist a little.
Chain tension - with a twist! aide_t Bikes - Talk & Issues 7 06-04-09 09:31 PM
A twist of the wrist 2 Horney Bikes - Talk & Issues 7 16-02-08 09:49 AM
wtd: twist grip m6rk Stuff Wanted 4 14-04-06 02:27 PM
Dublin, Mondello Park and a nasty twist........ Mariner SV Talk, Tuning & Tweaking 10 25-07-03 08:09 PM
