Old 01-03-13, 10:26 AM   #11
Wildkid
Default Re: Tutoro fitted to bibrackets?
While you are at it, my exhaust needs cleaning and polishing, the engine needs a good scrub, the paint needs a coat of wax and the dents in the fuel tank from where I dropped it need filling and repainting! Oh, my rear hugger and front mudguard have both come loose due to broken bolts.
I will be inside painting my nails and combing my hair!
Jump to it!
I dont mind being a handy man jayne but certaintly no ones biatch
Old 01-03-13, 11:03 AM   #12
Jayneflakes
Jayneflakes's Avatar
I can be persuasive!
When my bike is done, the wife's bike needs a clean and polish too and then the lawn needs mowing too!
Jayne you're a Pussy Magnet
Old 01-03-13, 11:06 AM   #13
Wildkid
Just to far... too far..
Old 01-03-13, 12:03 PM   #14
Jayneflakes
Me... too far?
Old 13-03-13, 11:07 PM   #15
muzikill
muzikill's Avatar
http://www.scottoiler.com/uk/Spares-.../Page-1-9.html
Do you know what size of dispenser plate it is?
Old 14-03-13, 10:47 AM   #16
Jayneflakes
I am fairly sure that it was this one.
Good luck.
Old 14-03-13, 08:42 PM   #17
muzikill
muzikill's Avatar
Good luck.
Matches the one i was looking at, ordered.
Thanks for the advice
Old 14-03-13, 10:19 PM   #18
better late than never i suppose.. yes its the 8mm one.
Old 15-03-13, 12:44 AM   #19
Jayneflakes
You are very welcome.
See, I can be a good girl sometimes.
Just not very often!
Fitting Tutoro oiler on Curvy - pics please! xena_wales Bikes - Talk & Issues 1 04-07-12 02:35 PM
Tutoro Chain Oiler RavenWire Hardware 25 11-05-12 09:52 PM
Front brake seized, thank you Tutoro! Dunn-y SV Talk, Tuning & Tweaking 20 04-03-12 08:56 AM
tutoro chain oiler? aaron020873 Bikes - Talk & Issues 21 16-11-11 08:32 PM
Tutoro Chain Oiler Gabriel2k Ancillaries 19 09-06-10 05:05 PM
