Old 03-01-09, 07:52 PM   #11
metalmonkey
Default Re: new battery required?
I have been having simlar issues, in that the battery has gone flat in several days, then the bike wouldn't start...When I put the bike on the optimate it says that my battery is weak.
However my bike has been running fine for well since I got back to London! Its started okay for work, then getting home, to soho and back then to watford and back today! Thats running heated grips on full power.
I do have a data tool alarm on the bike, as well. So will a good run sort the bike out? Its going back to have alarm looked at....I just hoping that it just needs a long run to get back up and running.
Old 03-01-09, 08:07 PM   #12
Batteryman
Sure, I'll fix something up, on Monday for the org members
Old 04-01-09, 01:17 PM   #13
chris8886
chris8886's Avatar
i like you a lot all of a sudden which particular battery would you think will suit my bike best?
AR08 to AR13-QUALITY!
Old 04-01-09, 01:40 PM   #14
TSM
The Sick Man
TSM's Avatar
yausa YTZ14S, more CCA than the 12, same size as the 12, newer gel type battery, ive got one on my SV and it now turns over and fires even on freezing days in less than 1s compared to my old battery which was on its way out after 5yrs, if it was not so cold then the battery would have been fine but my engine does not like slow cranking, does not help that its had the engine timing advanced. WEMOTO £69, get good battery it will last you.
The SV doesn't need a huge amount of power to turn it over, so I can't honestly recommend them for general use. However, if you keep your bike outside and the temp drops to -5 or more like tonight, then the extra power is a useful reserve.
You think, well compared to a IL4 its hungry for power, compared to TL i would say that even then it may be on par with it as the TL has decompressers that make it easier to start.
ps. A few things that people can do to help their bikes start in this cold weather.
1. Turn of all lights (granted cant be done on pointies) and heated grips etc..
2. Dont start bike in gear
3. If you have clutch bypass mod done, still hold clutch fully in when starting.
Old 04-01-09, 03:04 PM   #15
embee
embee's Avatar
Originally Posted by TSM View Post
yausa YTZ14S, .......... WEMOTO £69, .
Pop into your local Hondoody dealer and you should get a genuine Yuasa/Honda one for £50 to take away.
Old 04-01-09, 03:07 PM   #16
TSM
The Sick Man
TSM's Avatar
Sure, for the YTZ, normaly its YT14B, mine is a YTZ14S which is the gel ones, YT14B are taller batteries.
Old 04-01-09, 03:23 PM   #17
embee
embee's Avatar
Check the £50 link
Old 04-01-09, 03:23 PM   #18
TSM
The Sick Man
TSM's Avatar
Check the £50 link
coolio, get that then
Old 04-01-09, 03:56 PM   #19
MrTom
I was just about to buy a cheap EasyStart battery when I saw this. I'll hold off until tomorrow now, give you more .org business
Old 04-01-09, 04:38 PM   #20
Biker Biggles
Biker Biggles's Avatar
Just to clarify??????
If I walk into a Honda dealer and ask for a battery for a NTV700 Deauville I should be supplied with a YTZ14S for £50???????
K3 Battery required gerbrox Stuff Wanted 5 18-08-08 03:30 PM
New battery required SV Ste SV Talk, Tuning & Tweaking 3 19-12-05 03:28 PM
Prices for new battery required – urgently! Natasha SV Talk, Tuning & Tweaking 8 05-07-05 09:53 AM
Battery/Starting problem - new battery hasnt fixed it! Aaron SV Talk, Tuning & Tweaking 13 24-01-05 05:21 PM
Battery required timboid SV Talk, Tuning & Tweaking 21 06-12-04 07:57 PM
