Old 28-03-11, 11:55 AM   #21
Grant66
Grant66's Avatar
Default Re: Battery voltage help
Did you charge the new battery before fitting?
Grant66 is offline   Reply With Quote
Old 28-03-11, 01:35 PM   #22
Geodude
Geodude's Avatar
Yep, new battery fully charged on optimate 4 before fitting to bike
Old 28-03-11, 02:04 PM   #23
Geodude
Geodude's Avatar
Done reg rec diode test and results are:
Multimeter* Black - probe to red wire on reg/rec
MM*Red + probe to yellow #1 wire ON REG/REC = 0.574
MM*Red + probe to yellow #2 wire ON REG/REC = 0.575
MM*Red + probe to yellow #3 wire ON REG/REC = 0.574
MM*Red + probe to red wire on reg/rec
MM*Black- probe to yellow #1 wire ON REG/REC = 1.
MM*Black- probe to yellow #2 wire ON REG/REC = 1.
MM*Black- probe to yellow #3 wire ON REG/REC = 1.
**1. is the readout on multimeter when nothing is connected so no change**
MM* Red + probe to black/white wire on reg/rec
MM*Black- probe to yellow #1 wire ON REG/REC = 0.563
MM*Black- probe to yellow #2 wire ON REG/REC = 0.570
MM*Black- probe to yellow #3 wire ON REG/REC = 0.565
Multimeter* Black - probe to black/white wire on reg/rec
MM*Red + probe to yellow #1 wire ON REG/REC = 1.
MM*Red + probe to yellow #2 wire ON REG/REC = 1.
MM*Red + probe to yellow #3 wire ON REG/REC = 1.
Again no change on meter
MM* Red + probe to red wire
MM* Black probe to black/white wire = 1.
MM* Black - probe to red wire
MM* red + probe to black/white wire = 0.887
So any thoughts on readings?
Old 28-03-11, 08:16 PM   #24
Geodude
Geodude's Avatar
Anyone done a reg rec diode test and were the results the same as above? Should i be getting a reading instead of the 1. i get? just so i know if its the reg/rec before i order another one.
Old 28-03-11, 08:48 PM   #25
I have never done a reg rec diode test.
2 criteria
If it is getting correct input (plenty AC volts, confirmed post 16) and not giving correct output (confirmed twice) then it is f***ed. Simples.
Old 28-03-11, 08:52 PM   #26
Geodude
Geodude's Avatar
Ok cheers yc, i was trying to make my quid last longer
Old 28-03-11, 08:56 PM   #27
The readings look correct, but that's the "rectifier" part of the system. Since you don't have loads of AC frying your bike, or any burnt alternator coils, that's probably not the problem.
The other part of the reg rec is the crap bit, the regulator, it's old school tech which just dumps excess charge as heat, and is fragile. If you get a good new un they use MOSFET power transistors which switch the supply on and off, runs much cooler.
Old 28-03-11, 09:04 PM   #28
Geodude
Geodude's Avatar
Right i will look into the mosfet ones, thanks again yc.
Old 06-04-11, 01:12 PM   #29
Geodude
Geodude's Avatar
Right still not working right with brand new reg rec and brand new battery
Ignition off 12.86v
Engine at idle with lights on 13.30v
Engine rev at 5k with lights on 12.8v
So what am i missing here? Have done earth test light and have no problems either?
Old 06-04-11, 04:36 PM   #30
Test voltage between red wire at battery and live wire at reg rec, if this is couple of volts (DC) then that is where volts are going missing.
What reg rec you used?
What should a good battery voltage be? SVspeedr SV Talk, Tuning & Tweaking 62 22-08-16 05:27 PM
RST Voltage Leathers 454697819 For Sale - Other Bikes and General biking items 0 25-01-11 07:44 PM
Motorcycle Battery Voltage Monitor Lucas SV Talk, Tuning & Tweaking 21 27-02-10 08:32 PM
RST Voltage Gemaroo Suits 1 25-09-09 08:00 AM
Low voltage relays DarrenSV650S Bikes - Talk & Issues 21 16-03-09 09:16 PM
