Old 04-01-11, 11:40 AM   #71
Sally
Default Re: Caliper questions
Yeah I should stick to doing what I do best, and that isn't being on the tools...
Brakes are better, both pistons actually move now.
Shouldn't have used WD40, woops.
Couldnt do much with the rear, calliper bolts came off ok but the pin was stuck in.
Old 04-01-11, 12:01 PM   #72
dirtydog
Knob faced knobster
dirtydog's Avatar
You could try gluing a screwdriver to it, but if the 6mm or so of steel didn't move it, what makes you think 2mm of brittle glue will make owt other than a mess?
Oh you mean I shouldnt try this suggestion?
I managed to snap it doing it up, was only using a tiny little spanner so didnt have huge amount of leverage on it. Knew I should've got new ones when I ordered the seals for the calipers
2011 Speed Triple 1050
Old 04-01-11, 12:06 PM   #73
You might have a chance with an easy out then. (might!)
Old 04-01-11, 12:11 PM   #74
dirtydog
Knob faced knobster
dirtydog's Avatar
I really do hate those bloody things! will need to go search my box of random bits to see if I can find one now (theyre not worthy of being in my tool box
Old 04-01-11, 12:18 PM   #75
dirtydog
Knob faced knobster
dirtydog's Avatar
So do I go for stainless steel nipples to replace or just standard ones?
Old 04-01-11, 12:31 PM   #76
dirtydog
Knob faced knobster
dirtydog's Avatar
The offending nipple
oh and thats not rust on it just dust from cutting MDF next to it
Old 04-01-11, 12:38 PM   #77
BoltonSte
Can you not stick the caliper in a vice and use a small flat bladed screw driver?
If it's not in tight, then coming at an angle with the screw driver, on the inside lip of the thread as if you were using a wood chisel may be enough to turn it.
that always leaves you the easy out option for later.
Had an SV or three.
Street triple R - gone but not forgotten.
Now trying the lunacy that is KTM with a Superduke GT. for the pillion capability of course.
BoltonSte is offline   Reply With Quote
Old 04-01-11, 12:49 PM   #78
wattyfred89
wattyfred89's Avatar
I was going to start a thread just to express my pain but as you guys are talking brakes.....
New dust seals for my front pistons (little rubber rings that swell up, pop out and don't pop back in) £74!!!!!!
that is all
wattyfred89 is offline   Reply With Quote
Old 04-01-11, 01:13 PM   #79
husky03
that is all
you've been pumped hard then mate-complete rebuild seal kit from wemoto 50 quid
Old 04-01-11, 01:14 PM   #80
husky03
dd-i'd be getting a drill into that
Caliper upgrade - Questions. lawson17 SV Talk, Tuning & Tweaking 13 14-09-11 12:51 PM
Questions, questions - light bulbs and oil leaks. garynortheast SV Talk, Tuning & Tweaking 7 25-03-10 12:55 PM
help with caliper rebuild?? arcdef Thames Valley 3 04-01-09 05:36 PM
Questions questions...(funny noise,luggage, ferry) the_lone_wolf SV Talk, Tuning & Tweaking 23 23-05-07 07:19 PM
a few questions....well 5 questions....from a newb flynn209 SV Talk, Tuning & Tweaking 12 10-07-06 10:56 PM
