Old 02-12-08, 04:43 PM   #41
Dangerous Dave
Default Re: SV650 Centre Stand
Either way both will be better than a centre stand
Aye
Old 03-12-08, 06:08 PM   #42
Haluk
Gave up on the centre stand for now, having Scottoiler fitted this Sat instead. Will need some sort of a stand sooner or later for chain tension though.
Old 03-12-08, 06:08 PM   #43
Why? You set the chain tension on the sidestand.
Old 03-12-08, 07:06 PM   #44
Haluk
Again, I didn't know this was possible but you learn every day. Mind you the dealer told me so. And if dealers want to make money out of beginners, who know very little, then who is to stop them? (I suppose forums like this). So I will never need a centre stand or a paddock one?!!!
Old 03-12-08, 07:11 PM   #45
Depends what level of maintenence you want to do.
Personally I have access to front + rear paddock stands, an abba stand, many car jacks, a big bar in the ceilling. Pile of bricks. etc etc.
But really if you're going to pay someone else to do work you don't need anything.
Old 03-12-08, 07:25 PM   #46
Dangerous Dave
As every home spanner monkey should have, I have the same.
Old 03-12-08, 07:33 PM   #47
Sean_C
Slight derail. Who'd you get it off and where in cambs are you?
Edit- Your pic looks like it's beside PH Allins.
Old 03-12-08, 08:57 PM   #48
Haluk
Yes that's correct, PH Allins. I'm in Over. I think before I consider a stand I need to find out whether I need to do tension setting between services at all. If not, then I probably won't need one (mind I just learnt from Yorkie Chris that I don't need it for this purpose anyway so that's that problem gone). I keep the bike in a 8x6 shed, which I cannot turn into a workshop. Good to know you are in Cambridge?!
Old 03-12-08, 09:01 PM   #49
Sean_C
Check chain tension regularly, just incase- if it's well maintained (cleaned and lubed regularly) it'll probably be ok but it's always worth checking.
Yeah, I'm in Histon, not far from you!
Old 03-12-08, 09:01 PM   #50
Yes you do. Depending on maintenence. But as I said before you are supposed to check the chain tension with the bike on the side-stand!
curvy centre stand dizzyblonde For Sale - SV's and SV related items 22 08-03-09 11:36 AM
Centre Stand Shellywoozle SV Talk, Tuning & Tweaking 12 30-12-06 08:27 PM
cutting a centre stand out Warren Bikes - Talk & Issues 8 12-11-06 01:13 PM
Centre Stand drumwrecker SV Talk, Tuning & Tweaking 6 05-12-05 11:14 PM
Fitting a Centre Stand on an SV MartinM SV Talk, Tuning & Tweaking 9 21-06-05 08:16 AM
