Old 01-03-09, 06:53 PM   #21
Default Re: clutch
Good write up!
Originally Posted by noob-saibot View Post
Cool yer chickilitos dude, just want to know as thats the only bit of the clutch i never understood...
Basically, the worm drive turns the pull of the clutch cable into a push on the pushrod, which then moves the clutch plates apart. The screw adjuster adjusts/preloads the pushrod- if it's slack and not contacting the pushrod then there's slack to take up before the pushrod moves, which can lead to drag- the same amount of lever movement gets you less clutch. If it's overtight then the pushrod never quite returns to the neutral position, which can lead to slip- the clutch never quite fully grips
Old 01-03-09, 11:15 PM   #22
noob-saibot
Default Re: clutch
Aaah...so what is the benefit of 1/8th turn over 1/4? Making sure the clutch plates are fully apart when levers in or what?
Old 02-03-09, 07:56 PM   #23
Lucas
Default Re: clutch
Job done! a new cable and tuned adjuster, the clutch feels very nice
thanks all
Old 02-03-09, 08:08 PM   #24
Default Re: clutch
It's just that it happens to be the right amount
I wouldn't mess with the screw with the engine on. Did you loosen everything off before touching the screw?
Won't matter at all, the screw just pushes the clutch pushrod in the same way as the lever/worm does.
Old 02-03-09, 08:48 PM   #25
Dave20046
Dave20046's Avatar
Default Re: clutch
Ah cheers northy, I never dared! Thought it was safest advice until someone knowledgeable turned up.
Old 02-03-09, 09:06 PM   #26
Default Re: clutch
Oh yeah, definately.
Old 29-05-09, 09:25 AM   #27
-Ralph-
Default Re: clutch
Cool Anna, I did mine for the first time yesterday, but wish I'd read this as I used 1/4 turn. I don't suppose it matters, the clutch feels fine.
For anyone needing an easy to print version to take out to the garage, exactly the same instructions with pictures are in the workshop manuals, page 18 of manual 2 (periodic maintenance) and they are available here www.sv650.org/sv_manuals.htm, buch better that the Haynes manual I believe.
Old 29-05-09, 11:38 AM   #28
Sir Trev
Sir Trev's Avatar
Default Re: clutch
Originally Posted by Stingo View Post
I didn't do it whilst the engine was running. Stuff was all loosened prior to adjustment.
Did the adjustment (screwed it in and then out a tad) - fiddled with cable adjusters to tighten cable, started engine, selected first, let out clutch, bike went nowhere.
Turned off engine. Repeated above but unscrewed the little screw a bit further and so on.
Repeated about three time until the gear finally bit...
You have a problem there by the sounds of it. I've always done it the "Anna Way" (nice summary post!) and it works fine.
When you did up the locknut after turning the rod out a 1/8 turn you did hold the rod still at the same time didn't you? If not it would have moved in with the turning action of the locknut and be way out.
Old 20-06-10, 05:13 PM   #29
panosm
Default Re: clutch
I wentout with me nephew today (he is 11) to adjust the clutch on my bike. I had all theinstructions printed out and then my work phone rungso i had to leave the bike with my nephew in the garden....whe i came back the number 4 screww was completely untightened. i tried for over an hour to find the correct setup but with no luck....could anyone please help?
Many thanks in advance
Old 20-06-10, 05:45 PM   #30
panosm
Default Re: clutch
anyone?please help i need the bike first thing in the morning to get to work!!
Adjusting clutch lever cable - help please TC3 Bikes - Talk & Issues 1 09-05-10 04:06 PM
Adjusting clutch play lawriejones1 SV Talk, Tuning & Tweaking 8 01-12-08 09:10 PM
Adjusting Clutch Cable tonybmw92 SV Talk, Tuning & Tweaking 2 08-08-08 04:00 PM
Adjusting Clutch echomadman SV Talk, Tuning & Tweaking 5 16-05-05 03:41 PM
Adjusting clutch on sv650s? mordecai SV Talk, Tuning & Tweaking 3 29-03-05 04:39 AM
