Old 26-05-12, 08:22 PM   #51
muzikill
muzikill's Avatar
Bump.
Sent from my GT-I9100 using Tapatalk 2
Old 06-09-12, 12:36 PM   #52
pie_master
Default Re: Adjusting clutch.
Originally Posted by federer View Post
Just wanted to say thanks for the guide at the beginning of this thread.
I have spent ages fiddling with the clutch adjustment today and have it just how I want it now. Just need to sort out the free play and all will be perfect.
Ditto - did mine last weekend and it's miles better - thanks Anna / all
Old 25-06-13, 07:23 AM   #53
PyroUK
PyroUK's Avatar
Default Adjusting clutch.
Firstly thanks for the guide, secondly did this last night and all was good.
This morning however the bike won't start.
Does the clutch switch thing go from the lever or the worm drive area?
Everything on bike works just won't start. When the starter button is pressed the lights dim so don't think the button is knackered.
Any thoughts?
2011 Triumph Daytona 675, Arrow exhaust and QS!
PyroUK is offline   Reply With Quote
Old 25-06-13, 12:11 PM   #54
ChrisCurvyS
ChrisCurvyS's Avatar
Any thoughts?
Clutch switch goes from the lever mate - really easy to bypass to check if it's that.
Just pull out the switch which goes into the bottom of the lever joint, pull out the wires and join them (you can always solder them back in if you want to keep the nannying cut-out).
I'm not exactly sure why but before I bypassed mine, it sometimes wouldn't work if the lever adjusment was out.
Red Suzuki GN 125 - sold
Black Yamaha XJR400 - sold
Current - 2000 SV650S curvy, red. 1969 VW Beetle for the snow.
ChrisCurvyS is offline   Reply With Quote
Old 25-06-13, 02:02 PM   #55
Do not permanently bypass the clutch switch of a fuel injected bike.
Check you didn't disturb the switch connector when you were adjusting.
Old 25-06-13, 02:33 PM   #56
ChrisCurvyS
Course - it affects the fuel mapping doesn't it?
Didn't clock that it was a pointy and thus in possession of a little electronic brain. Should leave this advice business to the professionals.
Old 25-06-13, 04:18 PM   #57
PyroUK
PyroUK's Avatar
It affects the fueling!? Have just got home and it is starting, had a little play with the switch.
My adjustables don't use the switch at all, it now starts without having to pull the lever. Never noticed before as I always pulled the lever.
Old 25-06-13, 04:40 PM   #58
ChrisCurvyS
Yeah - Sid will prob cringe at my crude explanation but as I understand it, when it thinks the clutch is pulled in, the ECU changes the fuel mapping as you want different things out of the engine when pulling away etc.
If you bypass the switch, the bike thinks the clutch is pulled in permanently and your fuelling will be different.
Remember reading something in MCN about it being the source of a lot of pub myths about bpassed switches adding extra power - sometimes the altered map can feel more powerful due to steeper torque curves etc.
Old 25-06-13, 04:43 PM   #59
PyroUK
PyroUK's Avatar
Ah right.
So if it doesn't use the switch any more, can it be in "clutch in mode" permanently now then?
Can't say I have noticed any difference in the performance.
Old 25-06-13, 07:07 PM   #60
You didn't disconnect the kickstand switch, did you?
Adjusting clutch lever cable - help please TC3 Bikes - Talk & Issues 1 09-05-10 04:06 PM
Adjusting clutch play lawriejones1 SV Talk, Tuning & Tweaking 8 01-12-08 09:10 PM
Adjusting Clutch Cable tonybmw92 SV Talk, Tuning & Tweaking 2 08-08-08 04:00 PM
Adjusting Clutch echomadman SV Talk, Tuning & Tweaking 5 16-05-05 03:41 PM
Adjusting clutch on sv650s? mordecai SV Talk, Tuning & Tweaking 3 29-03-05 04:39 AM
