#21 |
Is there a longer clutch cable for sale somewhere?
#22 |
#23 |
#24 |
It fits easily in terms of length, but it just seems bent at the wrong angle.
#25 | |
Am I right assuming the switch boxes have to be re-routed as well instead of going round the shocks? |
#26 |
Oh, and one more thing ... How are you supposed to fit the brake fluid reservoir?
Thanks for all the advice ![]() |
#27 |
#28 |
#29 |
I have the ABM kit from Matt before he CNC`d his own stuff , the Clutch cable was moved in the frame to suitable position and came direct out of the frame and into the clutch , no wrapping it through forks or anything . The 90 degree tube for the cable shroud was angled downwards . Brake reservoir on mine was just screwed direct to the brake perch on my bike , no bracket required . I have replaced the Clutch Cable recently due to the miles I have done and decided to buy one from a Naked SV , cost me about £15 for an original Suzuki one and they are not that much longer to be honest , I could have just ordered a normal one and it would have still done the job .
#30 |
Got another one for you!
Inside each switch box there is a small plastic nipple that has a corresponding whole on each clip-on. Did you removed the nipple or did you drill a whole in the bars? If the later, how did you measure the correct angle? |
FAO Matts-yokes | DarrenSV650S | Idle Banter | 11 | 02-08-10 11:51 AM |
Current discount code for Comfort kits from 998cc.com | Matts-Yokes | SV Talk, Tuning & Tweaking | 0 | 02-07-10 06:55 AM |
Manx Matts birthday bimble. | Owenski | Pennine Massive | 69 | 07-12-09 07:02 PM |
998cc.com comfort kit | maff | Idle Banter | 0 | 04-11-09 11:24 AM |
Daytona 955i at Matts BBQ | fraser01 | South & West Surfers | 4 | 29-05-06 04:34 PM |
