#31 |
Colour the bar in with a permanent marker and fix the boxes at a high angle on the bar and screw them together , then rotate them to the right position very slowly ..... the nipples will cut a clear line through the permanent marker and the end point is where you spot drill your hole
#32 |
Thanks! This looks like is going to take a lot more time than I anticipated
#33 |
Should take 2 hours tops mate , and that is with brews and admiring your own work , oh ..... and enjoy bleeding those brakes ....... Snigger .
#34 |
If you add the extra trips at Screwfix for the security bits to undo those bolts, to HG for a replacement pair of heated grips (first ones were busted) it all adds up. But I very much enjoy it and with your guidance I should get there by the end of the day.lol
#35 |
If you were nearer I would come and do it for you .
#36 |
#37 |
Faired vs Naked clutch cables
#38 |
I used the old clip ons to measure the distance and then a blob of tippex on the nipple to get the orientation right.
I then punched the bar with a very sharp punch to stop the drill skidding. Then drilled 2 5mm holes. The bars are very hard, and my 12 volt dewalt cordless wasn't up to it. I switched to the 240V drill and it was a lot easier. Swarf goes everywhere so use a cover. Bleeding the breaks is a total basteward. It took me ages with a mityvac vaccum pump, but I eventually got them rock solid. I had air trapped in the master cylinder, that I removed by tapping it with a screw driver handle. All my advice came from here, especially from Phil "SPECIALONE". The only thing I couldn't replicate was I had to remove the air box and he didn't. Don't be tempted to use the OEM throttle cables, defo use the replacements. At full lock they are just too tight. |
#39 |
Any advice on adjusting / tensioning the throttle cable?
#40 |
I didn't need to really. Just put the gap on the screw tensions as close to the ones coming off and stuck em on. Worked fine.
FAO Matts-yokes | DarrenSV650S | Idle Banter | 11 | 02-08-10 11:51 AM |
Current discount code for Comfort kits from 998cc.com | Matts-Yokes | SV Talk, Tuning & Tweaking | 0 | 02-07-10 06:55 AM |
Manx Matts birthday bimble. | Owenski | Pennine Massive | 69 | 07-12-09 07:02 PM |
998cc.com comfort kit | maff | Idle Banter | 0 | 04-11-09 11:24 AM |
Daytona 955i at Matts BBQ | fraser01 | South & West Surfers | 4 | 29-05-06 04:34 PM |
