Old 21-08-10, 11:36 AM   #41
Default Re: Matts Yokes 998cc Comfort Kit fitment
You want a couple of mm of side ways movement where you can see the cable coming out of the adjuster by the engine side.
You dont want the cable too tight so it wont relax when throttle rolled off but not slack so bugger all happens when you throttle on, just nice the best way to describe it.
Disclaimer...
My terminology may be incorrect, but i know what i mean
BTW, Badger i took double that time, i didnt rush tbh, but i couldnt do mine in 2 hours, brake bleeding took at least an hour if not more.
Old 21-08-10, 12:11 PM   #42
barwel1992
an hour to bleed the brakes ??? take 15 min on the standard sv stuf
Old 21-08-10, 12:43 PM   #43
Im not the only one who had problems, its common, especially after changing the lines as well.
Just when i thought id got it, more air appeared, i was doing it manually though with no bleed device, just old fashioned method.
I also got rid of every trace of the stock fluid and put dot 5 in.
I have done many cars whole systems in less time i must add, 4 wheels.
Old 21-08-10, 02:01 PM   #44
maxinc
Speaking of breaks, I got 2 lines, one slightly longer than the other. The longer one I presume is for the nearside disc.
On one end, each of the line's head is slightly angled. Is this the part that connects to the master cylinder? Should the angle point inwards or outwards.
Sorry for asking so many questions (obvious for many of you) but want to do this right. The bike starts to look pretty awesome as I'm getting close to the end
Old 21-08-10, 02:19 PM   #45
I wouldnt know about yours cos i got mine elsewhere.
Offer them up and see what looks the best and most comfortable in terms of looks, function etc.
Mine werent perfect on mine i had an angle where i probably should have had a straight but it worked fine, just got on my nerves a little bit keep looking at it.
Old 21-08-10, 02:51 PM   #46
danf1234
My lines were a right faff. They seem about 5 cms too long so I had to make a clip, and buy a connector from goodridge. Brake lines were defo the biggest pian in the ar5e for me when doing the conversion.
Old 21-08-10, 02:56 PM   #47
maxinc
Lol ... when I was thinking I'm almost done ) Managed to connect them somehow to remain flexible but yes, they look a bit too long. Bleed time now ...
Old 21-08-10, 03:21 PM   #48
danf1234
Told you. Its a right royal pain in the back side. You need to get them just right of they will rub on the forks, or the fairing.
Old 21-08-10, 03:32 PM   #49
I'm gonna wait till I get the yoke and bars fitted then measure what length brake lines I need.
How did you guys decide what angle to have the bars at? I was thinking just 45 degrees to give the best height and reach...
Old 21-08-10, 04:13 PM   #50
danf1234
I just sat on the bike with them semi loose and moved them until I got the most comfy position for me. I tightened them up and THEN drilled them. I also doubled check with pics off Matts website that I hadn't done anything real daft that put them miles out of their intended position
FAO Matts-yokes DarrenSV650S Idle Banter 11 02-08-10 11:51 AM
Current discount code for Comfort kits from 998cc.com Matts-Yokes SV Talk, Tuning & Tweaking 0 02-07-10 06:55 AM
Manx Matts birthday bimble. Owenski Pennine Massive 69 07-12-09 07:02 PM
998cc.com comfort kit maff Idle Banter 0 04-11-09 11:24 AM
Daytona 955i at Matts BBQ fraser01 South & West Surfers 4 29-05-06 04:34 PM
