My speedo bulb has blown on my curvy SVS. Is there an easy way of changing it? Anyone done it before?
You have to take the whole unit out, my tacho bulbs gone so I have to do the same thing.
To be honest it doesn't take that long it s just the hassle... I'd say an hour and a half tops... I'm just to lazy to do it...
I can only see the first half of my speedo and nothing else on the dash at night (I have that many bulbs blown) after that I'm getting done what ever speed I'm doing, so its not that important!!!
Innuendo - it's great when you get it. sv650s (gone) gsx-r600 (gone) Street R675 (now living in Inbhir Nis ) |
#4 | |
![]() I have it down to 35 mins to remove and replace the whole lot. Just remember that you dont have to unbolt the screens lower to bolts. Remove it with the front center section ![]() |
when you do it be carefull there are screws and fasteners everywhere...
#6 | |
Mirror pods 1 cross head screw 2 6mm Hex bolts 2 rubber threaded grommets Each side pannel consists of 3 medium head 4mm hex bolts 1 large head 4mm hex bolt 1 push pin (Underneath front) 1 cross head screw (Front air duct) Front center section 4 4mm medium head bolts (2 become visible after you remove side pannels, 2 are underneath) (Leave the 2 3mm small head ones at the bottom of the screen and remove center section and screen combined) Clock shroud 1 4mm Medium head Bolt (In front of head stock) 2 Cross head screws Clocks to remove 4 7mm(i think) nuts with washers 1 Multi pin plug Clocks to dismantle 6 cross ehad screws As i said, replace all 3 bulbs with 1.2w versions form Halfords, all with the carriers attached. I have tried LED's but thier light angle doesnt light the entire clocks. So stick with the bulbs for now. HTH And thats from Memory...does that make me sad??? ![]() |
Very ...
![]() Cheers Ben |
Thanks for advice!
#9 |
i might give this ago.
Cheers for the advice! |
#10 |
It's the most annoying job there is on the SV, all that hassle for practically nothing.
Changing dash bulbs? | dazzaboy | Bikes - Talk & Issues | 17 | 05-10-12 09:29 PM |
Changing Speedo Bulbs? | dazzaboy | SV Talk, Tuning & Tweaking | 4 | 10-03-11 08:06 AM |
Curvy R&G tail tidy with Mini-Indy's - Changing Indicator Bulbs, how? | krhall | SV Talk, Tuning & Tweaking | 2 | 08-03-09 06:55 PM |
Changing Light Bulbs... | Drew | Bikes - Talk & Issues | 8 | 25-01-08 10:32 AM |
sv650s curvy- what are the light bulbs behind the speedo/tacho? | vzzzbuxt | SV Talk, Tuning & Tweaking | 2 | 19-09-07 04:48 PM |
