View Poll Results: Running in what's your view?
I only bought the bike to clean it at weekends so it will never get run in. 1 2.78%
I never go over 5000 revs anyway because I'm a wimp and I might damage something. 1 2.78%
Run it in by the book, the manufacturer knows best. Anyway I like having my piston rings full of oil sludge and carbon deposits. 27 75.00%
Be gentle for 50 miles, change oil and filter using ordinary mineral oil and spend the next 500 miles trying to kill the bike. 7 19.44%
Voters: 36. You may not vote on this poll
Old 19-10-06, 08:38 AM   #11
Kate
I've run in my GSX-R by the book, the way I see it the restrictions are probably there for a reason.
Old 19-10-06, 09:01 AM   #12
jambo
jambo's Avatar
While I'm not sure that I would necessarily stick religiously to a running in procedure I am ultra paranoid about letting bikes warm up at low revs and building them through a ride, and clearly beating the thing to within an inch of it's life from new is just not an option for someone that thinks like this on a daily basis
That said, never owned a new bike
Old 19-10-06, 09:39 AM   #13
skidmarx
I'm on my second SV and I've run them both in by the book. I've read plenty on here about the amount of oil an SV CAN use, and the dealer told me once that 'These twins can use a bit of oil, so check it regular'. I've never had to put a drop of oil in either bike, or even noticed a drop in level between services. Maybe this is because I've run them in?
Old 19-10-06, 09:41 AM   #14
Baph
Almost 6000miles in on my new (now not-so-new) K6, and I have to agree. She's never used a drop of oil over what weekend warriors would call a year!
Old 19-10-06, 09:48 AM   #15
Blue_SV650S
What’s funny is that modern cars don’t state a running in period … with modern engineering it is a thing of the past. So why do bikes still have a running in period??
600+ once the bores are glazed (which running in by the book will do) then they will remain that way until it gets honed (i.e. never unless you have a rebuild). If you want your bike to be oil tight and have max compression you need to thrash it from new (when up to temp obviously) to seat the rings properly. This majority of this process actually happens within the first few miles of running!!!
I have run in by the book in the past, but with what I know now, I’d thrash it initially to seal things, then just be a bit mindful that it is young after that until it has a few miles on the clock!!
The most important thing is that the bike (oil, water, components) is up to temp, if its not then that is when damage is done.
Old 19-10-06, 09:54 AM   #16
Baph
Every time my brother has bought a new car, or his wife has (yes, they're flash gits) it's always been stated as having a running-in period.
I think when my brothers wife bought her Renalut Clio, it was something like below 3k rpm for 300 miles, then below 6k rpm until 1000.
When my parents bought their brand new Saxo, this too had a running in procedure.
Has things changed that much in the last 2-3 years in terms of bedding engines in? (or at least the manufacturers recommended way)
Old 19-10-06, 10:00 AM   #17
DanAbnormal
Read this and decide for yourself.
http://www.mototuneusa.com/break_in_secrets.htm
Old 19-10-06, 10:02 AM   #18
Blue_SV650S
I don’t really do cars (new especially) myself, so can’t look at the manual to confirm. But on conversations with my dad (who is old and a traditionalist about such things as running in) … the last 3 cars he has had ALL have not specified a running in period … he has had lengthy conversations where he just couldn’t handle this concept!!! “Yes Yes dad, things have changed in the past 50 years”
Old 19-10-06, 10:11 AM   #19
Flamin_Squirrel
Because they're more highly tuned.
More knowledgeable people than you have said otherwise!
Old 19-10-06, 10:12 AM   #20
Ceri JC
What I read in Ride was something to this effect:
Thrashing it from new will make it make more bhp sooner, but also the engine will wear out sooner. Go easy on it and it will initally make less, but after a few thousand miles or so it will open up and make as much power as the thrashed bike does, but will also last a lot longer.
But then contrary to that, I've seen that website that advocates thrashing it from new and changing the oil & filter after the first 25 miles and shows much cleaner/smoother pistons from bikes run in this way.
I don't know what to believe. Without trying various ways of running in on a few dozen examples of a particular model of one bike (and then running them for 100,000 miles to see how running in effects longevity), it's pretty difficult to say comprehensively. Even then, it'd only be true for that sort of engine. Getting 100,000 miles on a dozen or so test bikes would be rather expensive R&D-wise, so I can't imagine Suzuki & co. do it. As someone else said, I suspect they edge on the side of caution.
My POV?
For a road bike, I'd run in according to the manufacturer's specifications. If it breaks, at least you've not voided your warranty. For a dedicated race/track bike(not that I've had one!); I'd thrash from new (once warm) to ensure it makes peak power early on. It's probably going to be wrecked/sold before 20,000 miles, so longevity isn't a concern.
With regard to car engines:
It's correct they don't need running in any more. I drive a lot of brand new cars and I've certainly noticed the engine feels a bit "tight" and slightly unwilling/less responsive than one with 10,000 on the clock.
The View From The Pub Tiger 55 SV Ecosse 5 02-06-08 07:34 PM
The View from my room at 21:19 plowsie Photos 14 30-05-08 05:10 PM
Running rough, running out of ideas. Sarj SV Talk, Tuning & Tweaking 17 04-12-07 06:45 PM
My view on the SV The Basket SV Talk, Tuning & Tweaking 4 03-12-07 08:46 PM
Please do not view this post Dicky Ticker Idle Banter 32 05-06-06 07:53 AM
