Old 29-06-08, 06:13 PM   #1
sottondan
Default 120/70/will it fit
just wondered would a 120/70 fit a curvy sv650s? nice n simple question. Thanks in advance
Old 29-06-08, 06:15 PM   #2
Dangerous Dave
Default Re: 120/70/will it fit
Yes it will, not worth doing to be honest and many people drop the forks through the yokes and this would compensate for that if it has been done. Plus the SV650 is not approved to run with a 120/70 tyre so if you have an accident you are buggered!!!
Old 29-06-08, 06:18 PM   #3
sottondan
well i just got offered a set of used (still loads of rubber left) d207 gp tyres rear is same size but front is 70 profile but they are £30 and im skint as long as they will fit i will have them would it be an idea to drop forks 10mm to compensate then?
Old 29-06-08, 06:21 PM   #4
Dangerous Dave
If you do it take it for a ride as standard first if it feels good then don't mess with it, tyres won't last long anyway so why alter the whole bike to suit.
Tip for anyone considering dropping the forks by 10mm is to fit stiffer spring in first, the OEMs won't cope!!!
Old 29-06-08, 06:22 PM   #5
sottondan
could i be a cheapskate and stick a spacer on top of spring
Old 29-06-08, 06:55 PM   #6
Yes it fits and it works, with standard mudguard and a sticky tyre you get lots of noise with gravel getting spat out.
My SV isn't approved to run GSXR suspension either... the insurance are aware that it's got "GSXR front running gear" so that includes a 120/70 ZR17 tyre.... Should be alright I reckon.
Old 29-06-08, 06:56 PM   #7
sottondan
sticky is what i want lol are they any good then?
Old 29-06-08, 06:57 PM   #8
Not really. Maybe a little different to turn in but nothing massive.
Old 29-06-08, 08:16 PM   #9
Steve_God
Yes it fits.
If you have fitted a Fenda Extenda then you may have to readjust the mudguard position slightly so that it gives more clearance, but after that there's no problems with it.
It will work fine without going to the effort of adjusting the forks - I personally have noticed bugger all handling differences by doing a straight swap, other than the initial 'tip in' seems faster.
Old 29-06-08, 09:56 PM   #10
Nah, that just increases preload not stiffness, gives you more problems to go on top of your soft springs. But DD's oversimplifying I think, the standard springs will still be fine for lightweights.
